1st gen b16a JDM wiring harness...useable?
i am doing a swap into a 90 dx. i know about the rewiring that i usually have to do but i have never had a COMPLETE JDM harness that i can plug right up before. so now what exactly do i need to wire? just find the 2 and 4 injectors at the plug on the passenger side and tap those wires and run them to the ECU or what?
It can't be directly used because it is ment for a right hand drive car and your ecu is on the wrong side; also, if it could be used it would not meet up with the interior harness.
uh ...last time i checked the engine harness didnt go all the way through to the ecu. there are plugs on the fenderwells, anyway it DOES hook up. resisterbox and all came with this harness and IT PLUGGED RIGHT UP.My question is...what wires do i have to tap or add to make this work. I the car seems to have all the inj. wires inside the car on pins A1,A2,A3,A4. I'm lost....need wiring guru!!!
