Tranny noise - HELP!!!
Old Oct 12, 2004 | 07:22 AM
EK45VTi's Avatar
Default Tranny noise - HELP!!!
Hi!
I am having problems with tranny humming... the car is 1996 Civic coupe D16Y7 bone-stock with 90.000 miles on it...
Did anyone ever have a problem with wrong tranny fluid (too thin or too thick)???
If yes, is there any acompanying noise that goes with wrong choice of tranny fluid?
For example, I have this constant humming noise when I drive (it is very similar to TIRE RUBBING SOUND but it is not it - it is a bit deeper and constant)... It doesn't make the difference if the engine is turned on or off, and it doesn't matter if the car is in gear or neutral...
Immediately when wheels start moving, the humming noise starts... so if I just let my car cruise at neutral and turn off the engine, the sound is still there so I doubt there is something wrong with mainshaft or countershaft)
I already replaced wheel bearings (both left and right - Koyo) and differential bearings (NTN)... the sound is still there - NO CHANGE
That made me think... this sound started when I first changed the tranny fluid when I got the car...
Instead of Honda MTF or GM Syncromesh FM I put in SHELL 10w40 semi synthetic...
I cannot find Honda MTF or GM fluid here where I live so I was forced to use engine oil...
Now my question is... would the oil that is TOO THIN cause tranny-humming...
Cos guys at Honda dealership said that 10w40 oil is TOO THIN for the tranny and that I should use ONLY 15w40 or higher (20w and so on) in our climate/temperatures...
Is that true?
They also said they DO NOT KNOW where this sound is coming from...
And if I am right noises can come from: (note that sound is there also when car is off and in neutral)
- tires - NO
- tire rubbing - NO
- wheel bearings - CHANGED
- CV joints - CHECKED
- tranny shafts - CHECKED
- differential - CHANGED BEARINGS
Is that it or there is something else that should be on that list????????
Help me cos I am stuck!!!
Off topic:
I was planning to replace the whole tranny for EX tranny but the guy wanted to rip me off and sell me the wrong tranny... thank God for H-T-ers and their knowledge on tranny and part codes
I found 2 more EX tranny but they both have f*cked up 2nd gear syncro... another words, there is NO good EX tranny out there to find
HELP GUYS, YOU ARE MY ONLY CHANCE!!!!!!
Old Oct 12, 2004 | 07:24 AM
Spade's Avatar
Default Re: Tranny noise - HELP!!! (KKVTi)
First things first, go to your local Honda dealer and buy MTF.
Old Oct 12, 2004 | 07:29 AM
EK45VTi's Avatar
Default Re: Tranny noise - HELP!!! (Spade)
I CAN'T
They don't carry it!!! ********* told me that they do NOT order Honda MTF cos the engine oil is THE EXACT SAME as Honda MTF and that they don't see any perspective in putting MTF...
If I want to change the fluid there they will just put some Castrol 10w40 Magnatec in it...
It seams that they have some exclusive contract with local Castrol supplier... IDIOTS!!!
They should sell HONDA PARTS and not some AFTERMARKET SHUBIDUBI STUFF
Old Oct 12, 2004 | 07:32 AM
opkjoblacsh's Avatar
its a honda ive never been in a honda that hasent whined or humed...i wouldnt really worrie about it unless its really bad like somthings bad wrong with it
Old Oct 12, 2004 | 07:33 AM
iggyracer's Avatar
http://www.manhonda.com/ap/ind...D=210
here you can order it if need be.
Old Oct 12, 2004 | 07:48 AM
EK45VTi's Avatar
Default Re: Tranny noise - HELP!!! (opkjoblacsh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opkjoblacsh &raquo;</TD></TR><TR><TD CLASS="quote">its a honda ive never been in a honda that hasent whined or humed...i wouldnt really worrie about it unless its really bad like somthings bad wrong with it</TD></TR></TABLE>
Are you serious???
Cos it doesn't sound like something is VERY WRONG... but it is noticable and annoying...
Like I mentioned before, this sound is very very similar to TIRE RUBBING SOUND... it is a bit deeper, not as loud as tire rubbing and it is CONSTANT...
If tire rubs like HU_HU_HU_HU_HU ... this sound is like HUUUUUUUUUUUUUUU
Old Oct 12, 2004 | 07:51 AM
EK45VTi's Avatar
Default Re: Tranny noise - HELP!!! (iggyracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iggyracer &raquo;</TD></TR><TR><TD CLASS="quote">http://www.manhonda.com/ap/ind...D=210
here you can order it if need be. </TD></TR></TABLE>
Thank you
But I do not have a credit card to pay over internet and I live in Europe so that narrows my options...
I asked my friend who lives in Germany and he also said that German dealers put engine oil and DO NOT have Honda MTF... It is like the TWILIGHT ZONE . tu du du du ... tu du du du
Old Oct 12, 2004 | 08:09 AM
Spade's Avatar
Bummer.
So internet ordering is out. Do you have any local race shops that you can visit? Talk to them about gear oils and see where they get it or if they have it in stock or not?
Old Oct 12, 2004 | 09:48 AM
EK45VTi's Avatar
Well I've been in most of them but none of them even heard about GM syncromesh FM...
And Honda MTF is only a Honda "thing" and can be only ordered from Honda (here were I live)...
I'm stuck...
I will just try to put in some 15w40 mineral oil and see what happens and then, if I am not succesful, I will see other options...
Any suggestions? Besides tranny fluid?
Old Oct 12, 2004 | 10:58 AM
EK45VTi's Avatar
baboonstyle
Oct 9, 2006 11:04 AM
jikespingleton
Jul 17, 2006 07:50 AM
tur3oDC4
Nov 25, 2004 11:05 AM
jgl3
Acura TL, RL & ZDX
May 10, 2004 12:28 AM
01-1293
Jul 12, 2002 11:11 AM
