It's nearing completion! h22/hb allmotor
Old Oct 12, 2004 | 12:13 AM
civicsitek GanGsTa's Avatar
Default It's nearing completion! h22/hb allmotor
Specs are
H22 block 1994
h23 crank
h23 rods w/ arp bolts
type s pistons
rebuilt and ported head curteousy of me
milled .0020"
imagine engineering header
ported/flowed intake manifold w/ removed secondaries
balance shaft eliminator kit courtesy of Hondaddict
removed oil squiters
stage 1 DSS axles
uberdata
compression calculated at 12.2:1.
1992 civic cx hb CW
ERS 400F/500R agx f/koni yellow r w/ extended shock travel
Modified by civicsitek GanGsTa at 5:27 PM 10/25/2004
Old Oct 12, 2004 | 12:14 AM
Default Re: It's nearing completion! h22/hb allmotor (civicsitek GanGsTa)
If someone can resize the pics I'll take down the big ones.
Old Oct 12, 2004 | 01:43 AM
eL's Avatar
eL
here ya go:
Old Oct 12, 2004 | 01:45 AM
TLo's Avatar
TLo
Old Oct 12, 2004 | 02:00 AM
H.A.R.T B18C1EG6's Avatar
Default Re: It's nearing completion! h22/hb allmotor (TLo)
dam thats sick with it
Old Oct 12, 2004 | 02:51 AM
Eyes Only's Avatar
Default Re: It's nearing completion! h22/hb allmotor (H.A.R.T B18C1EG6)
Drop It Likes it Hott
Old Oct 12, 2004 | 04:50 AM
hondainspired's Avatar
Default Re: It's nearing completion! h22/hb allmotor (Pho Bos)
ahhh.. yes... thats gonna be quick for ya....
Old Oct 12, 2004 | 05:50 AM
93H22ACX's Avatar
looking good
Old Oct 12, 2004 | 06:05 AM
zer0.'s Avatar
Default Re: It's nearing completion! h22/hb allmotor (93H22ACX)
damn,will be a beast for sure.
Old Oct 12, 2004 | 06:25 AM
McNizzle's Avatar
Default Re: It's nearing completion! h22/hb allmotor (zer0_2_6ixty)
Old Oct 12, 2004 | 06:52 AM
vinnymack's Avatar
very nice, HCP mounts?
Old Oct 12, 2004 | 07:03 AM
Buktheng's Avatar
hot bohs
Old Oct 12, 2004 | 07:04 AM
alleyezonme's Avatar
Default Re: (vinnymack)
don't forget to post up #'s and slips when you are done
good luck!
Old Oct 12, 2004 | 07:53 AM
92slowvic's Avatar
civicsitek GanGsTa looks very clean....what did you use to paint the trans and valve cover looks hot
Old Oct 12, 2004 | 07:56 AM
RobbieG35's Avatar
12 Years Strong
Default Re: It's nearing completion! h22/hb allmotor (92slowvic)
NICE! That thing is going to rip!
Old Oct 12, 2004 | 08:41 AM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
i love that swap but i hope its just a drag car and your not going for great handling
Old Oct 12, 2004 | 08:54 AM
Deemeetree's Avatar
Electrician
Nice. Wish I had enough $$ for an H22 build.
Old Oct 12, 2004 | 11:17 AM
Default Re: (SpoolinEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolinEK9 &raquo;</TD></TR><TR><TD CLASS="quote">i love that swap but i hope its just a drag car and your not going for great handling</TD></TR></TABLE>
To answer the questions, the mounts are place racing and yes I have had some trouble with them. Before the build I broke the tranny mount at the track on street tires but I think that was due to a missed shift and over rev.
I just used high temp engine paint from the machine shop I used to work at, so I don't expect the paint to last forever.
As far as the suspension goes it should handle quite well. ERC 400F/500R agx up front koni yellow out back with the entended shock travel by the top hat modification. I have about 1.25" of extra travel up front and almost 2" out back. Should handle great. And it's not a drag car or anything like that. I just built it to be a street beast, thats all. Full Si interior, nice system, etc.
Modified by civicsitek GanGsTa at 5:24 PM 10/25/2004
Old Oct 12, 2004 | 11:39 AM
hype r 555's Avatar
Default Re: (civicsitek GanGsTa)
damn that thing's going to be a torque monster......definatley post #'s up once you dyno.....
Old Oct 12, 2004 | 12:09 PM
OLM-02R's Avatar
nice... dont forget to post 1/4 # and dyno#
Old Oct 12, 2004 | 12:19 PM
ludesleep's Avatar
Default Re: (OLM-02R)
Damn that's some tight clearance
Old Oct 25, 2004 | 04:28 PM
bump for new pics.
Old Oct 26, 2004 | 02:11 AM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
why'd you remove the oil squirters?
Old Oct 27, 2004 | 01:47 AM
Default Re: It's nearing completion! h22/hb allmotor (PreIudeSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreIudeSI &raquo;</TD></TR><TR><TD CLASS="quote">why'd you remove the oil squirters?</TD></TR></TABLE>
wont clear the crank after multiple efforts.
Old Oct 27, 2004 | 02:13 AM
Root79's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsitek GanGsTa &raquo;</TD></TR><TR><TD CLASS="quote">
wont clear the crank after multiple efforts.</TD></TR></TABLE>
What do you mean with that, can't understand the idea.
My English
