Problem after ITR TB install
Sup guys,
I have a Skunk2 IM on my gsr motor and had what looked like a GSR tb but i switched it out today with an ITR tb. But after the install my idle was ok but when i would gas the car. The throttle seemed to get stuck at 2k and stay there. Is it because im not using a Type R throttle cable?
Modified by spankey167 at 1:17 AM 10/12/2004
gsr and itr DO require different throttle cables, they're a diff part number..but did you try just trying to open up the throttle by manually pressing on it? i'm guessing if it works manually..then its prob the cable not having enough play to open up throttle
should be around 30 bucks from the dealer...but most likely dont carry it in stock *special order*
