Is it the timing
Old Oct 11, 2004 | 08:12 PM
4drNrunnin's Avatar
Default Is it the timing
I have a 92 Civic Lx when i am driving in a steady pace of acceleration after i shift the car kinda looses power/or lags then it comes right back.
any suggestions on what this might be.
thanks
also have an extremly low idle after car is warmed up.It sits just a hair above 0
Old Oct 11, 2004 | 08:30 PM
rodrez.'s Avatar
Default Re: Is it the timing (4drNrunnin)
Could be timing, have you checked it lately? Also, how are the plugs? Are the wires old? Could also be a fueling issue, how is your fuel filter looking?
Old Oct 11, 2004 | 08:40 PM
4drNrunnin's Avatar
Default Re: Is it the timing (rodrez)
Um plugs and wires are a little old Ill check em out. Replaced fuel filter about 6,000 miles ago
Iv owened the car for about 12,000 miles never checked timing.Is that a basic at home thing to check or would i have to take it to a shop.
Oh i also had to replace the gas tank a little while back and i used the salvaged fuel pump because it looked better than mine could that be an issue.
Old Oct 11, 2004 | 09:44 PM
HXvtec's Avatar
u can check the timing at home just buy a timing light. my car only does this when im low on gas. so i would check your fuel pump and make sure its ok.
Old Oct 11, 2004 | 09:49 PM
4drNrunnin's Avatar
Default Re: Is it the timing (HXvtec)
What is a timing light?
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drNrunnin &raquo;</TD></TR><TR><TD CLASS="quote">.
Oh i also had to replace the gas tank a little while back and i used the salvaged fuel pump because it looked better than mine could that be an issue.</TD></TR></TABLE>
Yes, it definately could be the culprit.
Old Oct 11, 2004 | 10:09 PM
b18bcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drNrunnin &raquo;</TD></TR><TR><TD CLASS="quote">What is a timing light?
wow you need to search
Old Oct 11, 2004 | 11:24 PM
00Red_SiR's Avatar
All Motor Mentor
If you're not sure what a timing light is, take it to a shop and have them check it for you. That old fuel pump could be the problem for sure...pull it out of the tank and check to see if the filtering sock is ok (ie: not collapsed and blocking the intake or full of crap).
Its me DUB
May 2, 2008 06:58 PM
ThatOneOG
Jul 7, 2007 12:57 AM
dragaholic
Feb 23, 2007 11:05 PM
Briman2021
Jul 22, 2006 08:01 PM
CivicRaping
13
Mar 22, 2005 10:38 PM
