fuel pump prime ?
yeah i just got done doing mpfi conversion on my std hatch. it had also a bolted up greddy kit with 96-00 EX manifold (yes alot of modifications were done to fit this manifold).
now for some reason, the fuel pump isint priming ? i dont see how its not. but for whatever reason, even with no blown fuses. its not priming.
some might say.. is the ecu dead ? well yeah i swapped out the new ecu with old pm5 (which WAS working when car was stock) but still nothing ? i re checked my wiring at the ecu but. still nothing ?
another opinion might be... "is the main relay bad?" well i stuck that ho in the freezer and put it back in but its still not priming.
so im left with 2 ideas. both ecu's for some freak reason are deader than dead. or 2. the fuel pump went bad. other than that. im fuggggin stumped. because nothing i did had anything to do with the pump priming.
any help is GREATLEY apreciated. the cars been out of operation for about a month now and im really waiting to see what the new azenis with poly eura inserts and turboedit tuning feelz like.!!!
please help.
please help.
main relay...just because you freeze it doenst mean its going to work if its broke...
check it.
http://www.we-todd-did-racing....=.jpg
check it.
