Need help with my suspention... PLZ help.
Old Oct 11, 2004 | 02:37 PM
Intense3.2's Avatar
Default Need help with my suspention... PLZ help.
Thanks for taking a sec. to look, any help would be greatly appreciated.
I have a 94 accord coupe, i have neuspeed sport springs, with koni yellows (neuspeed editions) i bought an eibach camber kit the one that replaces the ball joints, & installed it last weekend, it has made my handling horrible... it feels almost as if i have no shocks... any time i hit a lil bump in the road it sounds like the spring fully compresses. any time i take a turn (not fast at all) the tires are sqeeling, now the tires are wearing even worse on the insides than they were before... im having the car aligned tomorrow. have i bought the wrong camber kit? something not installed right? anyone else have this set-up that can tell me what they did to correct the camber? help me out, - Thanks.
Old Oct 11, 2004 | 04:45 PM
honda lover's Avatar
Default Re: Need help with my suspention... PLZ help. (Intense2.2)
well sport springs can be a bit of a rough ride. but not that rough. did you leave the stock bump stops in place or remove? as for the tire wear that should get corrected when you allign specially since you can now adjust camber. are those konis adjustable? you may have to do some tweaking. good luck.
Old Oct 11, 2004 | 04:46 PM
suspendedHatch's Avatar
The kit doesn't correct the camber. It makes camber adjustable. The alignment corrects the camber. Just slapping on a kit can make the car have even more negative camber if you don't know what you're doing. That's how it sounds in your case. Just get it aligned.
If the balljoint bushings are urethane, that would explain the increased ride harshness.
romoracing
Suspension & Brakes
Mar 3, 2007 07:44 PM
Didly
Suspension & Brakes
20
Jan 30, 2007 03:16 PM
Intense3.2
Oct 11, 2004 02:41 PM
tegra91
Jun 11, 2004 02:23 AM
Bishop Don Shizzle
Mar 20, 2003 10:56 AM
