EK hatches with b18c1 swap... which catalaytic converter are perfect fit or it must be customed?
Old Oct 11, 2004 | 02:11 PM
SivikHatch's Avatar
Default EK hatches with b18c1 swap... which catalaytic converter are perfect fit or it must be customed?
ek hatch with b18c1 swap. which catalaytic converter are perfect fit onto EK exhaust system or it customed made is the only way?
Old Oct 11, 2004 | 03:40 PM
IDriveHonda's Avatar
Default Re: EK hatches with b18c1 swap... which catalaytic converter are perfect fit or it must be customed?
I am still d series, but when I got a header, I picked up a cat for a 99-00 Si and it worked out good. Something will probably have to be modified depending on what exhaust you get because our stock cats are on the manifold. Fortunately I think my exhaust was supposed to be for an EX so it all bolted right up. It stuck out a little to much for me in the rear, but it was nothing a torch and a welder couldn't fix.
Old Oct 11, 2004 | 04:16 PM
JDMFreak's Avatar
i have a b-series swap with b16 header and GSR exhaust, and it does not need the cat converter , but your best bet is with a test pipe or if you want to go street legal i would use a GSR it prolly better then the Si
Old Oct 12, 2004 | 03:21 PM
SivikHatch's Avatar
Doesnt each one have different lengths?
Old Oct 12, 2004 | 03:23 PM
Luserkid's Avatar
I had a stock one that i found out was gutted later on, then i had a regular one custom installed to pass smog, and now i dont have one at all
SL0-hatch
Feb 24, 2021 09:32 AM
xlee08
Nov 28, 2014 10:19 AM
TYPERman2001
Mar 28, 2007 06:02 PM
Natural Aspirations
Dec 8, 2005 07:18 PM
coupe_hybrid
Jul 6, 2005 03:27 PM
