Msd Sci and 2 step module?
Old Dec 16, 2001 | 12:41 AM
Rhetoric's Avatar
Default Msd Sci and 2 step module?
Is it posibble to hook up the standard Sci with a 2 step module? Most of the Msd ads say to use with the ones with the rev limiter. Any one know? Also does Msd make a pill for 9300 or 9500?
Old Dec 16, 2001 | 06:40 AM
rainforest's Avatar
Default Re: Msd Sci and 2 step module? (G S R)
i thought the sci had came with a 2stage. the msd makes a 9500 pill they make 14000 rpm pills also. but 2 stage owns get it ***.
Old Dec 16, 2001 | 09:20 AM
Rhetoric's Avatar
Default Re: Msd Sci and 2 step module? (rainforest)
I have the Sci and it doesnt have a 2 step? I basically just need something for a rev limiter for the Sci, any suggestions?
Old Dec 16, 2001 | 09:37 AM
rainforest's Avatar
it has the input for the pill though
Old Dec 16, 2001 | 12:05 PM
Mista Bone's Avatar
D Tranny Guru
Does you SCI have a place for a revlimiter chip? If so then plug the 2 step module ($56) into and follow directions.
BTW the clutch start switch makes a good ground circuit for setting the lower rpm limit.
If you SCI didn't come with the built in limiter, then your gonna have to do some adding on.
tigueremalo
Sep 4, 2006 01:31 PM
CIVICD16A9
Jul 4, 2005 08:26 AM
torr
Aug 4, 2004 08:08 AM
M.A.R.C.
Jun 20, 2004 02:56 PM
Specialblend27
Feb 17, 2003 09:46 AM
