I need some advice on converting obd0 to obd1
Old Oct 11, 2004 | 01:19 PM
Sinner's Avatar
Default I need some advice on converting obd0 to obd1
Here is the situation,
I have a obd1 motor with obd1 distribtuor.
I have a 89 hatch STD (dpfi) obd0 car that has no motor. I got a std obd0 wiring harness.
My idea is go to the boneyard and get a obd1 ecu plus the interior wireing harness that goes to the fuse box.
Then hook up the obd1 wireing harness to the obd1 ecu.... i just dont know about the cluster wires and such.
Any input?
Nick
Old Oct 11, 2004 | 01:33 PM
Blown90hatcH's Avatar
Default Re: I need some advice on converting obd0 to obd1 (Sinner)
Do-able but not advisable. If you have the time, go for it man. I would suggest getting the Helms manual as well before you start.
Jason
Old Oct 11, 2004 | 04:22 PM
Sinner's Avatar
alright, what would you do?
Old Oct 11, 2004 | 04:28 PM
Default Re: (Sinner)
DPFI to MPFI and OBD0-1 conversion harness. Or DPFIOBD0-OBD1 conversion harness. But I guess I am baised. If you want to attempt it, I would suggest getting the service manuals and go for it if you have the time.
Old Oct 11, 2004 | 04:45 PM
dr_latino999's Avatar
Default Re: (Blown90hatcH)
It truely is just a matter of time, patience, and the mastering of the English language so that you can stare at the Helms all day and be able to understand what wire goes where. If I had the time, or a spare car I would do it.
But midway through it I would get so pissed off I would give Blown90 here a call and grab one of his conversion harnesses
Old Oct 11, 2004 | 05:21 PM
CRXBart's Avatar
Default Re: (dr_latino999)
http://www.knology.net/~jediklc/obd0toobd1swap.htm
I used that, worked great. very good directions, make your own jumper harness and save lots of money too.
Old Oct 11, 2004 | 05:53 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">alright, what would you do?</TD></TR></TABLE>
Do the DPFI to MPFI conversion and use blown's obd0-obd1 harness. This will save alot of time and most likely headaches in the long run. Doing the Full interior OBD1 conversion would be cool but, not worth it IMHO.
Phil
dr_latino999
236
Mar 28, 2020 12:34 AM
zapzach
19
Feb 24, 2012 10:35 AM
E_F_9
Dec 22, 2005 02:26 PM
C4wrx
Aug 13, 2002 10:03 AM
h46it
Jun 18, 2002 05:23 PM
