gsr or ls/vtec
Old Oct 11, 2004 | 12:17 PM
EFin' Kyle's Avatar
Default what motor
which motor do u preffer for all motor?
Old Oct 11, 2004 | 01:05 PM
mrspeaker's Avatar
Default Re: what motor (crxstreetracer90)
A fully built high compression lsvtec motor...Just my opinion.
Old Oct 11, 2004 | 01:15 PM
lunchboxEF91's Avatar
ls vtec
Old Oct 11, 2004 | 01:26 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (lunchboxEF91)
poor mans type R b16 head GSR block
Old Oct 11, 2004 | 01:31 PM
dr_latino999's Avatar
Default Re: (Ace$nyper)
GSR to start with and than work from there. Sure my overall displacement is down about 45ish or so CCs but the block out of the bag is better suited for high-reving power.
Old Oct 11, 2004 | 01:33 PM
The DX Rex's Avatar
Default Re: (dr_latino999)
GSR, it will last longer, unless u got money like that, LS/VTEC is unreliable
Old Oct 11, 2004 | 01:40 PM
Default Re: (nyhustla2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyhustla2k &raquo;</TD></TR><TR><TD CLASS="quote">GSR, it will last longer, unless u got money like that, LS/VTEC is unreliable</TD></TR></TABLE>
Now that there is libel, so no more of that. A LS/VTEC can be built as reliable as any motor, it is just of matter of how you go about things and if you cut corners.
Old Oct 11, 2004 | 01:43 PM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">
Now that there is libel, so no more of that. A LS/VTEC can be built as reliable as any motor, it is just of matter of how you go about things and if you cut corners.</TD></TR></TABLE>
Exaclty..
as long as u use a Gsr girdle..arp bolts..Dont drive like an *******..It should be reliable,,
Old Oct 11, 2004 | 02:57 PM
EFin' Kyle's Avatar
Default Re: (Mrspeaker)
well the motor would be a racfe motor so aftermarket everything so i dont think i have to worry bout that i am just looking for power and torque. which would be best for an all motor race motor
-Kyle
Old Oct 11, 2004 | 04:01 PM
Default Re: (crxstreetracer90)
GSR block with CTR Pistons and some wild *** cams, toss in a pretty header, and I'm feeling it Well from the OEM expectancy anyways,
In the world though of All-Motor, sleeve the block, bore it out to let's say 84mm, some 12.5:1 pistons, and again the wild cams etc. and you can push some serious HP and some Torque to boot.
jxhxb
10
Dec 3, 2007 03:37 PM
ej8hybrid
16
Aug 23, 2005 09:09 PM
limpy
Jul 14, 2005 01:40 PM
Mr si99
Jun 26, 2005 11:12 AM
4door_gsr_ftw
May 13, 2003 11:30 PM
