Is there another way to remove paint instead of sanding? How about paint thinner?
Old Oct 11, 2004 | 10:02 AM
trooper0641's Avatar
Default Is there another way to remove paint instead of sanding? How about paint thinner?
If i just splash my whole car with paint thinner would the paint rub off?
Old Oct 11, 2004 | 10:51 AM
One day...'s Avatar
Default Re: Is there another way to remove paint instead of sanding? How about paint thinner? (trooper0641)
it will eventually....but would be very time consuming. i'd recommend to just sand it
Old Oct 11, 2004 | 10:58 AM
98civic4dr's Avatar
brake fluid --- lol i heard they sell special paint thinner just for auto paint still gonna take forever i would imagine --- but wont grind the metal like sanding
Old Oct 11, 2004 | 11:01 AM
khmboostedeh2's Avatar
Default Re: Is there another way to remove paint instead of sanding? How about paint thinner? (98civic4dr)
aircraft stripper
Old Oct 11, 2004 | 11:41 AM
x00gsr's Avatar
Default Re: Is there another way to remove paint instead of sanding? How about paint thinner? (Jeterkm02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeterkm02 &raquo;</TD></TR><TR><TD CLASS="quote">aircraft stripper</TD></TR></TABLE>
Works the best. just spray let it set and spray off.
Old Oct 11, 2004 | 12:09 PM
Default Re: Is there another way to remove paint instead of sanding? How about paint thinner? (x00gsr)
i just bought the aircraft paint remover thingy midjiggy. Instead of a spray its comes in a ozzie form so i can brush it onto my car. Works really well...a lot better than sanding!
Old Oct 11, 2004 | 12:34 PM
undertheradar's Avatar
Please dispose of that stuff properly. It should NOT be washed down the drain. It remains caustic even after you wash it off.
Old Oct 11, 2004 | 12:44 PM
Archidictus's Avatar
Unceasing Measure
Aircraft stripper will take everything off down to the metal, so if you want to go that route, that would be the best way to get there. That also makes it harder to repaint the car because you'll have to spray everything directly on metal rather than on a surface with some tooth, i.e. sanded paint or primer.
Anyhow, there are actually posts showing how to and the results of spraying aircraft stripper on your car as a paint-prep procedure. This really shouldn't be done, though and is a ****-poor excuse for trying to skip steps in a process that's 99% prep.
Old Oct 11, 2004 | 12:48 PM
evilcivilian's Avatar
You can sandblast it, a sandblaster shouldn't cost too much. It will give it a nice metal rough surface.
wdissident
Paint and Body
Jan 25, 2009 09:09 AM
vipcivic
Paint and Body
Nov 15, 2008 05:48 PM
JDM RHD eg6
13
Nov 20, 2006 10:08 AM
peiku
Jul 25, 2005 10:49 PM
deeweezy
Aug 17, 2003 07:19 AM
