D15b2 5-speed transmission on d15b1 engine?
Old Oct 11, 2004 | 08:07 AM
Bandit74's Avatar
Default D15b2 5-speed transmission on d15b1 engine?
I was wondering if a 5-speed transmission off of a 1990 DX hatchback d15b2 will fit on a 1990 STD hatchback d15b1. If so, what all else is required to make this transmission fit? Would I have to get a new clutch, flywheel, axles, shift linkage - basically anything in addition to just the transmission?
Old Oct 11, 2004 | 08:23 AM
tgreaves's Avatar
Default Re: D15b2 5-speed transmission on d15b1 engine? (Bandit74)
Everything should be good with it.. The DX tranny is kinda shitty for performance since it has a 3.88 final drive.. But will be good for gas mileage..
Old Oct 11, 2004 | 09:07 AM
Bandit74's Avatar
Default Re: D15b2 5-speed transmission on d15b1 engine? (tgreaves)
Mainly would like to get it because everytime I get to around 53 mph, my hand instintivly goes to the shifter to shift. Performance isn't really an issue. And good gas mileage is one of the reasons I have this car. How much do these usually run?
Old Oct 11, 2004 | 09:42 AM
tgreaves's Avatar
You can usally pick up a dx tranny pretty cheap.. If your really looking for gas mileage then get an hf tranny..
Old Oct 11, 2004 | 10:20 AM
Bandit74's Avatar
What's an HF transmission? Is that from a CRX?
Old Oct 11, 2004 | 10:21 AM
tgreaves's Avatar
Default Re: (Bandit74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bandit74 &raquo;</TD></TR><TR><TD CLASS="quote">What's an HF transmission? Is that from a CRX?</TD></TR></TABLE>
Yep.. Its geared really high for good fuel mileage..
Old Oct 11, 2004 | 11:20 AM
Bandit74's Avatar
How does the HF compare to the 4-speed transmission in the STD?
Old Oct 11, 2004 | 11:21 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bandit74 &raquo;</TD></TR><TR><TD CLASS="quote">How does the HF compare to the 4-speed transmission in the STD?</TD></TR></TABLE>
Errr... Not too sure on that one.. I know the hf trans is one of the highest geared ones out there but I dont know the stats against the std 4-speed..
Old Oct 11, 2004 | 11:34 AM
Bandit74's Avatar
Does the hf bolt onto a d15b1 without anything to add?
Old Oct 11, 2004 | 11:55 AM
eumoria's Avatar
yes, yes, and yes
I have a D15B1 in an 88STD with a CRX 5-Speed DX transmission on it.
The HF will fit, the Si will fit, the STD will fit, any cable D-series will fit.
Old Oct 11, 2004 | 11:56 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bandit74 &raquo;</TD></TR><TR><TD CLASS="quote">Does the hf bolt onto a d15b1 without anything to add?</TD></TR></TABLE>
If the dx tranny will bolt on to it then the hf will also..
Old Oct 11, 2004 | 12:04 PM
Bandit74's Avatar
Great - thanks. However, what else would I have to get besides just the hf transmission to work in my car? Would I have to get a new clutch, flywheel, axles, shift linkage - basically anything in addition to just the transmission?
tgreaves's Avatar
What year is your current tranny??
Old Oct 11, 2004 | 12:11 PM
Bandit74's Avatar
Default Re: (tgreaves)
1990.
Old Oct 11, 2004 | 12:12 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bandit74 &raquo;</TD></TR><TR><TD CLASS="quote">1990.</TD></TR></TABLE>
Your good.. Just take one tranny off and put the other one on.. The 88's are different than the rest and the 90-91 have a bigger clutch than the 89's but the 89-91 trannies are all interchangable with each other..
Old Oct 11, 2004 | 02:26 PM
Bandit74's Avatar
Okay, so, if I were to get an '89 - not an '88 - hf transmission, I wouldn't have to get a different clutch. If I were to get a '90-'91 hf transmission, I would have to get a clutch that fit in the hf transmission.
Is this correct?
Modified by Bandit74 at 5:56 PM 10/11/2004
Old Oct 11, 2004 | 06:13 PM
Bandit74's Avatar
Anyone?
Old Oct 11, 2004 | 06:58 PM
Bandit74's Avatar
Got IM.
Old Oct 11, 2004 | 07:11 PM
tgreaves's Avatar
No.. You can get an 88-91 tranny and it will fit an 89-91 clutch.. The 89's had smaller clutches than the 90-91 but they all(89-91) had the same tranny..
justamechanic
Oct 5, 2005 05:35 PM
Schaz
10
Oct 10, 2004 05:54 AM
CRXBart
Jun 29, 2004 07:40 AM
johnclaunch
Jul 7, 2003 06:53 AM
wu tang
Mar 4, 2002 04:13 AM
