Aftermarket cat convert. question.
Old Oct 11, 2004 | 05:32 AM
jpw04si's Avatar
Default Aftermarket cat convert. question.
I put a high flow cat on my 04 si and came up with this code P0420 Catalyst System Efficiency Below Threshold from the diagnostic machine. I had the car reset because the engine light came on, and now the light is off and has been ever since. My question is this. When you put an aftermarket race cat on your car do you need to buy some type of aftermarket sensor for it or can you somehow have the computer reprogramed to accept the diff. air/fuel ratios? Maybe a chip to help the ECU? The car has readiness codes and I guess the cat has the system clearing that particular code because its not meeting the stock requirments. Thanks in advance for any advice/insight/experience.
04 civic Si
Injen Cold Air Intake
Header
High flow cat
aftermarket muffler
Neuspeed Springs--- (Just getting started on this new car.)
Old Oct 11, 2004 | 05:58 PM
PrettyLude's Avatar
02 simulator
Chrs5060
10
May 9, 2011 09:38 PM
B16AGUY
Nov 18, 2008 06:39 AM
Brandon31386
Jul 18, 2006 04:36 PM
JoshuaVTEC
Sep 7, 2005 12:43 PM
DocV
Dec 21, 2001 06:33 AM
