Head gasket for 30psi (B18c)?
Old Oct 11, 2004 | 04:20 AM
u_tal's Avatar
Default Head gasket for 30psi (B18c)?
Hello guy's!
I have civic B18C engine with darton kit sleeves.
I had a COMETIC head gasket and he didn't hold this much of boost.
Can somebody recommand me the best head gasket for this kind of boost?
Thank you
Udi
ISRAEL
Old Oct 11, 2004 | 04:41 AM
PrettyLude's Avatar
i've seen people do it on the stock head gasket, or try the cometic hp one
Old Oct 11, 2004 | 05:15 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: (PrettyLude)
Stock will do fine. I do however suggest o-ringing your shizzle. It will help. Im just going by the experiences ive had also. thanks, good luck!
Old Oct 11, 2004 | 06:33 AM
u_tal's Avatar
o.k ... you know the stock one looks little tiny near the COMETIC.....
So do i need to trust the stock one?(it's all happend when i chang the turbo to GT3540R)
Old Oct 11, 2004 | 06:38 AM
HT's Biggest Loser
Default Re: (u_tal)
Yeah cometics (some if not most) are thicker, but if your running 30psi, Im assuming (for your sake) that you have a built and sleeved motor, and a adequate engine management. If so, theres no need for a thick headgasket if the car is tuned right, and especially if the motor can withstand the high boost..
Like i said, Stock will be fine..
Old Oct 11, 2004 | 07:26 AM
SiR831's Avatar
Default Re: (SIXTYdashONE)
Do you guyz use copper spray on the head gasket?
Old Oct 11, 2004 | 07:28 AM
HT's Biggest Loser
Default Re: (SiR831)
Use copper spray, or you can be brave and Use Spray paint
Old Oct 11, 2004 | 08:05 AM
X-Mazda 3 Racer's Avatar
Stock gaskest can handle well over 30 psi of boost. I have seen them hang at over 1000 H.P. Copper spray is what I use and recommend, as well as good headstuds. Check out our web-site http://www.goldeneaglemfg.com Hope this helps.
Old Oct 11, 2004 | 08:13 AM
gitwidit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote"> I do however suggest o-ringing</TD></TR></TABLE>
Any major advantages to o-ringing compared to a step-deck?
Old Oct 11, 2004 | 08:37 AM
HT's Biggest Loser
Default Re: (GITWIDIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">Any major advantages to o-ringing compared to a step-deck?</TD></TR></TABLE>
Honestly, thats a good question, but i dont really think theres that huge of a difference.. I always wanted to try a step deck just because.. Anyone care to comment?
Old Oct 11, 2004 | 10:05 AM
GSC Motorsports's Avatar
o ring
golden eagle headgasket to your bore (they use oem and bore it out)
no copper spray
holding up great - made 734 hp on the setup so far
james innes
Old Oct 11, 2004 | 04:08 PM
u_tal's Avatar
o.k.... now i got the gasket how much power i need put when i'm closing the head? (i havw special tool for that)22ft/lb?
Old Oct 11, 2004 | 04:11 PM
B00ST2nR's Avatar
Default Re: (u_tal)
stock HG and ARP Head Studs.
If you want a Thicker Cometic HG that will lower your CR, click the link in my sig. I'm selling it.
Old Oct 11, 2004 | 04:27 PM
u_tal's Avatar
Thank you!
Old Oct 11, 2004 | 11:34 PM
sicsixone's Avatar
Default Re: (u_tal)
another thing that you might do is put a straight edge on the deck of your block and make sure that none of your sleeves have dropped.
Old Oct 12, 2004 | 01:21 AM
u_tal's Avatar
Default Re: (jonsswapshop)
Old Oct 12, 2004 | 01:58 AM
ExospeedAMcrx's Avatar
Default Re: (u_tal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u_tal &raquo;</TD></TR><TR><TD CLASS="quote"> how much power i need put when i'm closing the head? (i havw special tool for that)22ft/lb?</TD></TR></TABLE>
Just to make sure. You are asking on:
How much torque is needed to bolt the head down?
Old Oct 12, 2004 | 09:21 AM
u_tal's Avatar
Default Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">
How much torque is needed to bolt the head down?</TD></TR></TABLE>Yes!
Old Oct 12, 2004 | 09:56 AM
HT's Biggest Loser
Default Re: (u_tal)
I did mine to 78ft/lbs...
This is Jersey tho, ive seen over 100 .
Old Oct 12, 2004 | 05:00 PM
sicsixone's Avatar
if your using stock head bolts i wouldnt go over 70 ft/lbs honda spec is 63 ft/lbs with clean motor oil.and its very important to torq your cams to spec if they are over tightend you will loose power or worse damage cams or cylinder head. 8/1.25mm 20 ft/lbs.
6/1.0mm 7.2 ft/lbs
Bc3
Dec 10, 2006 10:41 AM
K20 EG
May 8, 2003 09:49 AM
InfamousRS
Dec 15, 2001 06:02 PM
therealnapster
Sep 9, 2001 08:07 PM
