Need help, worried about my cooling system!!!!!!!!!!! need a cause about my effect
Old Oct 10, 2004 | 11:22 PM
Skank_aSS_Dara's Avatar
Default Need help, worried about my cooling system!!!!!!!!!!! need a cause about my effect
I drive a 92 hatch with a d16z6 blah blah i recently installed a camshaft and whatever goodies it need to run weeks later my temp. guage is rising towards the H once in awhile, so i got fed up and bought a brand new honda OEM waterpump because i've seen some leaks from the timing belt side, and also replaced my thermostat and a new radiator cap. Everything went smooth again for 2 weeks but now my temp guage is going up a quarter away from H while my car is still on, I turned off the car, started it back up still went back to the same spot on the guage so i just tried to engage the car in a moving motion the temp guage drops back to normal so i guess its normal, but somehow my resevoir bottle always get overflowed............... whats the cause????
sorry for the long story hope i didnt loose anybody TIA
-dara
Old Oct 11, 2004 | 12:58 AM
sudds's Avatar
Default Re: Need help, worried about my cooling system!!!!!!!!!!! need a cause about my effect (DaRa_Da_SkAn
Did you flush out the system, and make sure the fan is turning on?
Old Oct 11, 2004 | 01:04 AM
stripes777's Avatar
check out your radiator, i no my old one had a buncha small rocks and the fins were bent, it would overheat on hot days. i got a dual core radiator at autozone for 99 bucks, good stuff now!
Old Oct 11, 2004 | 07:52 AM
i flushed out my system yes, my fan automatically turns on when my key is in the ignition and i have a koyo radiator
Old Oct 11, 2004 | 09:12 AM
anybody need more info........ or maybe it just acts like this
Old Oct 11, 2004 | 09:56 AM
00Red_SiR's Avatar
All Motor Mentor
could also be the beginning of a headgasket problem...
Old Oct 11, 2004 | 10:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">could also be the beginning of a headgasket problem...</TD></TR></TABLE>
d0h had a feeling
jax93
Dec 27, 2016 04:19 PM
rktechteg
Dec 29, 2008 05:17 AM
twenty
Jul 21, 2005 04:32 PM
verseone
May 24, 2002 01:12 PM
#417R
May 5, 2002 01:47 PM
