Some idle issues
Old Oct 10, 2004 | 06:09 PM
bambbrose's Avatar
Default Some idle issues
I just converted my car (96 dx coupe) to obd1 using a p06 ecu, I have a d16y8 intake manifold, and I'm using a d16z6 throttle body and IACV.
My car isn't throwing any codes but since I switched to the 2 wire IACV for the obd1 ecu, my car is idling funny. It idles at 800 when warm, but it's sputtering slightly, and then every 30-45 seconds or so it'll drop down to 300-400 rpm and then almost die. It'll slowly climb back up to 800 rpm and then repeat itself.
I've cleaned the IACV, and bled the air out of the coolent. Anybody have any other suggestions? Also the IACV is humming pretty loud, and then it shuts up if I unplug it. I've tried 2 different IACV's and they both make the same loud humming sound.
TIA
Old Oct 10, 2004 | 06:11 PM
civiccpedx's Avatar
Default Re: Some idle issues (bambbrose)
I have had the same problem with my original IACV. But i haven't tried cleaning it. I have heard that you have to make sure to clean it really good. But besides that I don't know any options but to buy a new one and they are like $300 from Honda.
Old Oct 10, 2004 | 06:35 PM
bambbrose's Avatar
Yea I'm about 95% sure that it's not the IACV, but I've heard of many other things causing weird *** idles. I checked for vaccum leaks but haven't found any.
Old Oct 10, 2004 | 06:43 PM
Slow_Em1's Avatar
Default Re: (bambbrose)
idle screw??...
Old Oct 10, 2004 | 07:16 PM
bambbrose's Avatar
I still need to mess with the idle screw, but I'm pretty sure thats not it. How would I go about adjusting that?
djandy
14
Aug 28, 2014 10:10 AM
dohc15
12
Oct 10, 2012 07:36 PM
hondadude_rudo
Nov 16, 2010 08:35 AM
drumking15
Mar 28, 2007 12:12 AM
untitled
Aug 26, 2003 08:47 AM
