plz help me understand!
Old Oct 10, 2004 | 05:43 PM
Arch-Angel's Avatar
Default plz help me understand!
Sorry to bother you all, I was just hoping someone could explain the difference between Saturated and peak and hold injectors to me!!
I want to knw which ones to get.
Thanks in advance.
Old Oct 11, 2004 | 05:06 AM
EE_Chris's Avatar
Default Re: plz help me understand! (Arch-Angel)
P&H: low-ohm (2-3ohm) and require either individual resistors (10ohm) or the OEM resistor box (4 10ohm resistors in a pack together). These were used in 88-91 Civics.
Saturated: high-ohm (12ohm) and do NOT require additional resistance. These are used in 92+ Civics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arch-Angel &raquo;</TD></TR><TR><TD CLASS="quote">I want to knw which ones to get.</TD></TR></TABLE>
Get either of them - just make sure that the total resistance seen by the ECU is correct.
Old Oct 11, 2004 | 06:19 AM
Arch-Angel's Avatar
Default Re: plz help me understand! (EE_Chris)
I see, so it makes no difference whatsoever to performance?
So in 92 prelude, I should probably go with the Saturated ones...
Old Oct 11, 2004 | 07:03 AM
EE_Chris's Avatar
I am a proponent of running the correct injector type for the injector driver being used.
You see, the way each injector is opened and kept open, is different between the two units, however it has become common place to run P&H injectors, with some additional resistance, with ECUs that originally used saturated style injectors.
Are you gonna harm anything - no, just so long as the correct amount of resistance is achieved.
Typically, because of the way P&H injectors are triggered, they are more responsive when asked to 'open'.
I'm not gonna say it makes a difference or not in performance - I'll let someone who has used the two, to chime in on that issue.
Old Oct 11, 2004 | 08:59 AM
91civicDXdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arch-Angel &raquo;</TD></TR><TR><TD CLASS="quote">I see, so it makes no difference whatsoever to performance?
If you notice, 92-95 preludes, although OBD1, still have the resistor box and thus use peak & hold injectors..
Flava
Sep 25, 2006 08:20 AM
k00lt1nt
Apr 22, 2005 09:16 PM
Bictorious
Mar 11, 2004 06:30 AM
PanamaVTI
Jan 21, 2004 12:14 PM
Altered
Dec 31, 2003 04:26 PM
