b18c1 in 1989 crx hf everythign is wired up but no spark obd1
Old Oct 10, 2004 | 02:13 PM
deftones0817's Avatar
Default b18c1 in 1989 crx hf everythign is wired up but no spark obd1
Just put the engine in and tried to start it the spark plugs arent gettting any spark. I'm getting fuel though.
If cam timing is off would the car still get spark?
Could my distributor gone bad? The motor started last year when it was in another car.
I'm positive the timing is rigiht but my friend suggested the cam timing might be off but it cranks over fine no interferance issues.
DEF
Old Oct 10, 2004 | 02:46 PM
oldschoolfreak's Avatar
Default Re: b18c1 in 1989 crx hf everythign is wired up but no spark obd1 (deftones0817)
i had the same problem in my 91 when i put a B16 into it. it has to do with the wiring. it was dual point fuel injection right?
Old Oct 10, 2004 | 02:49 PM
Redline130's Avatar
Hard to say, could be a number of things as you know (grounds, ignitor, coil, etc.). How does the cap and rotor look on the inside? New sparkplugs I assume? Any CEL's?
Old Oct 10, 2004 | 03:04 PM
if you go to http://www.hasport.com they should have a list of the differences in the wiring to the ecu. it has to do with the fuel injectors because they send a signal to the distributor to tell it what cylinder to fire, along with the crank sensor and so you have to wire it in right or you wont get spark. like i said i just had the same problem with my swap last week. but for more info just look at hasport.
Old Oct 10, 2004 | 03:18 PM
Default Re: b18c1 in 1989 crx hf everythign is wired up but no spark obd1 (oldschoolfreak)
im using blown hatches obd0-obd1 with obd0 fuel injectors im getting fuel. Just no spark at the plugs. So Im thinking the igniter is bad...need to find another dizzy. Im getting plent of fuel. The wiring is all right all i hade to do was the wires to the dizzy and oxygen sensor and vtec stuff (3 wires 1 was ground).
The distributor hadnt been used in a year or so so im thinking maybe it went bad just sitting on a shelf in my garage? The started had to get smacked with hammer to get it to turn But the car is cranking just not starting and im getting fuel. Wiring is all correct. Where are all the grounds suppose to be? Diagram I know i saw on on here somewhere.
DEF
Old Oct 10, 2004 | 03:23 PM
i see but i had the same exact problem i was getting fuel and i thought everything else was right but i wasnt getting anything out of the distributor. i put all new components in it and still the same it was the wiring to the ecu but if you 100% sure about the wiring then it might be the distibutor components
Old Oct 10, 2004 | 03:30 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">im using blown hatches obd0-obd1 with obd0 fuel injectors im getting fuel. Just no spark at the plugs. So Im thinking the igniter is bad...need to find another dizzy. Im getting plent of fuel. The wiring is all right all i hade to do was the wires to the dizzy and oxygen sensor and vtec stuff (3 wires 1 was ground).
DEF</TD></TR></TABLE>
There should be a ground on the thermostat housing, on from the valve cover to the chassis, one from the tranny to the chassis and one from the battery negative to the chassis. I would check those first, then try switching ignitors and/or coils.
Old Oct 10, 2004 | 04:25 PM
Default Re: b18c1 in 1989 crx hf everythign is wired up but no spark obd1 (Redline130)
man now you guys got me wondering if hondaguyef wired my dizzy right I'm pretty sure he did...he did his and his works so Im guessing mine is write. I'll check again tomorrow.
DEF
Old Oct 10, 2004 | 04:34 PM
CrazyKoreanCrx's Avatar
I would check the wiring and if its not that then you got a bad distributor. But most likely its the wiring. I'm have the same problem with my car but I had it running for a second then it died out. So good luck with your car.
Old Oct 10, 2004 | 04:37 PM
Default Re: b18c1 in 1989 crx hf everythign is wired up but no spark obd1 (CrazyKoreanCrx)
yeah if those 2 distributor wires are crossed for obd 0 - obd1 will the car not get spark?
DEF
Old Oct 10, 2004 | 04:59 PM
Are you getting a code?
Old Oct 10, 2004 | 05:12 PM
well i talked to jason (blown90hatch) and im pretty sure I have the 2 white wires crossed now...I'll try tomorrow and if it starts I'll post pictures...if not ill be back for more advice...
DEF
Old Oct 10, 2004 | 06:35 PM
alright just let us know what happens either way and what you did because there will be more ppl that have the same problem that can be helped.
Old Oct 10, 2004 | 06:43 PM
quicksol95's Avatar
hey if you need help tomorrow i am off give me a call
Old Oct 11, 2004 | 04:13 AM
hondaguyef's Avatar
Default Re: b18c1 in 1989 crx hf everythign is wired up but no spark obd1 (slowsohccivic)
I was actually thinking that the 2 white wires may have been crossed. I matched it exactly w/ my dizzy setup but, it's worth a try. I'll be over later for some more trouble shooting.
Phil
Old Oct 11, 2004 | 06:42 AM
Default Re: b18c1 in 1989 crx hf everythign is wired up but no spark obd1 (hondaguyef)
no problem phil. Im sorta leaning toward the wires to its just one of those things i guess. Phil you rock man thanks for everything so far.
DEF
Old Oct 11, 2004 | 01:15 PM
hondaguyef wired everything correctly...my dizzy is bad...nastyboyII brought one over and tested it on my car...i orded a new one from distributor king should be in tomorrow i overnighted it. Let you guys know what happens.
DEF
Old Oct 11, 2004 | 01:30 PM
Blown90hatcH's Avatar
Def,
Sounds good man. Let me know when you get that distributor king distributor. Many times the colors do not correspond with OE colors. If this happens and you and masta phil can't figure it out, hit me up and I will make it happen.
Jason
Old Oct 11, 2004 | 03:33 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">no problem phil. Im sorta leaning toward the wires to its just one of those things i guess. Phil you rock man thanks for everything so far.
Not a problem at all man. You know that. We'll get her running soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Def,
Jason</TD></TR></TABLE>
I think I'll probably just make him a conversion harness or I'l repin that dizzy king dizzy in accordance w/ mine. It Depends on what he wants to do though. Once again Jason, thanks for all of the help bro, you are the **** .
Phil Trujillo
Old Oct 26, 2004 | 02:15 PM
PSIMR2's Avatar
So did you ever figure this out?
Im having the exact same problem but im sure the wires might be off.
Old Oct 26, 2004 | 02:20 PM
Default Re: b18c1 in 1989 crx hf everythign is wired up but no spark obd1 (PSIMR2)
the problem was due to a bad wire/ vaccum line being hooked up wrong and, timing being off.
DEF
T_Rav
Jul 7, 2014 05:47 PM
EF8DayDreamer
Sep 30, 2012 07:31 PM
n_i_c_k
Jul 28, 2010 06:57 PM
Sturg
Oct 27, 2009 12:04 AM
lina sok
Mar 20, 2009 09:30 PM
