just got alignment and I got a printout, what do these number mean? explain please.
Few weeks ago, left Front wheel hit a pothole, 1 month later left front wheel seen threads in the inner side of tire. Just got my alignment and the car feels much better in acceleration now.. steering wheel always straight, MY question is I got a prinout and can someone tell me what all these number mean? which ones are my alignment BEFORE I got the car aligned? and AFTER?.. in other words, How do I read this thing?
car is 1.25" dropped all around with comptech springs and tokico illuminas
LEFT FRONT
CAMBER------>min=-1.17, Nominal=-0.17, Max=0.83, Actual=-1.6
CASTER------->min=0.17, Nominal=1.17, Max=2.17, Actual=0.6
TOE------------>min=-0.04", Nominal=0.00",Max=0.04", Actual=0.01"
RIGHT FRONT
CAMBER------>min=-1.17, Nominal=-0.17, Max=0.83, Actual=-1.2
CASTER------->min=0.17, Nominal=1.17, Max=2.17, Actual=1.1
TOE------------>min=-0.04", Nominal=0.00",Max=0.04", Actual=-0.01"
FRONT
CROSS CAMBER----->Actual=-0.4, min=-----, Nominal=0.00, Max=-----
CROSS CASTER------>Actual=-0.5, min=-----, Nominal=0.00, Max=-----
TOTAL TOE------------>Actual=-0.00", min=-0.08", Nominal=0.00", Max=0.08"
SETBACK-------------->Actual=-0.02
LEFT REAR
CAMBER------->min=-2.00, Nominal=-0.75,Max=0.00, Actual=-1.7
TOE------------>min=0.02", Nominal=0.04",Max=0.08", Actual=-0.06"
RIGHT REAR
CAMBER------->min=-2.00, Nominal=-0.75,Max=0.00, Actual=-1.0
TOE------------>min=0.02", Nominal=0.04",Max=0.08", Actual=0.02"
REAR
TOTAL TOE------>min=0.04", Nominal=0.08",Max=0.16", Actual=0.08"
THRUST ANGLE---->0.04
LEFT FRONT
RIGHT FRONT
FRONT
LEFT REAR
RIGHT REAR
REAR
as long as ure actual number is somewhere in the min and max ure cool. dont know if thats ure question but ehh.
what u wanna know? do u know what toe camber and caster is?
what I wanted to know is how do I read this chart? Were these the numbers AFTER my alignment? If yes, what WAS my alignment before? Is the "actual" what I had or what I have after? I'm confused?
