How long can I drive titanium retainers?
Old Oct 10, 2004 | 12:56 PM
eg4matze's Avatar
Default How long can I drive titanium retainers?
I have heard I must change ti retainers after 13000 miles. Is this true?
Matthias
Old Oct 10, 2004 | 01:08 PM
pwrofdrm's Avatar
Default Re: How long can I drive titanium retainers? (eg4matze)
Never heard of this... bump for you
Old Oct 10, 2004 | 01:10 PM
Agent Zero's Avatar
They should last you a long time. As long as they are a good brand.
Old Oct 10, 2004 | 01:37 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg4matze &raquo;</TD></TR><TR><TD CLASS="quote">I have heard I must change ti retainers after 13000 miles. Is this true?
Matthias</TD></TR></TABLE>
Depends on how the car motor is worked. But yes, you will end up needed to change them, as they don't last as long as OEM.
Old Oct 10, 2004 | 01:42 PM
Slopoke's Avatar
Default Re: How long can I drive titanium retainers? (redsihatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redsihatchback &raquo;</TD></TR><TR><TD CLASS="quote">They should last you a long time. As long as they are a good brand. </TD></TR></TABLE>
Depends on what you consider a long time.
I had a JUN retainer break on me after about 4 years of use.
It had actually worn thin and then the outside ring of it broke off, but luckily it just dropped down onto the inner spring and prevented any damge from happening.
After replacing them, I noticed that ALL of the JUN retainers were worn very thin. They would have broke at any time.
A friend of mine had the same experience. One broke and the rest were worn thin.
I'm not sure exact mileage, but I'm keeping track with these retainers and plan to figure out a good milage to change them.
Old Oct 11, 2004 | 04:26 PM
eg4matze's Avatar
Default Re: How long can I drive titanium retainers? (Slopoke)
ok thanks, so you think I can drive crower retainers for a long time?
Old Oct 11, 2004 | 04:35 PM
wiLLY mAZE's Avatar
that ? is like me guessing your weight over the phone all you can get is maybe a ballpark figure ....it all depends on how your hard your driving your car..if you daily drive it they will last u alot longer then if your dragstripping
Old Oct 12, 2004 | 08:25 AM
eg4matze's Avatar
Default Re: How long can I drive titanium retainers? (***** mAZE)
can I see it when I must replace the retainers, or can you say me some good steel retainers?
Old Oct 12, 2004 | 02:58 PM
eg4matze's Avatar
when must I replace the titanium retainers?
Old Oct 12, 2004 | 03:16 PM
Padawan's Avatar
Darth ModerVader
By inspecting them regularly, you should be able to tell when they're beginning to wear. Depending upon your setup, there most likely isn't a need for something other than the stock pieces.
Markland Photo
Jan 2, 2008 08:55 PM
DCFIVER
Oct 25, 2006 09:16 PM
01ITR#173DC2ning
Jan 31, 2005 04:59 PM
m0t0rhead
Feb 10, 2004 08:38 AM
crxste
Dec 4, 2003 11:12 AM
