cel problem, it turns on and off....
Old Oct 10, 2004 | 12:16 PM
silvervtecrx's Avatar
Default cel problem, it turns on and off....
well i got an 88crx w/ an ls swap.. about 1 mile after i drive the car the cel turns on but wen i turn off the car the cel turns off..
what do u guys think is causing this problem?
i cant check the code with the paper clip trick coz the cel turns off after i turn off da car? any input on how to check the code? i dont wanna pay 50 bucks at shop jus to check for da code? any input would really help...
Old Oct 10, 2004 | 12:22 PM
dr_latino999's Avatar
Default Re: cel problem, it turns on and off.... (silvervtecrx)
Ok, first off it is THE, no da. Spelling is your friend, learn to love it. Anyways, what OBD level are you running your swap at, 0 or 1?
Old Oct 10, 2004 | 12:38 PM
Default Re: cel problem, it turns on and off.... (dr_latino999)
its obd1 (p06)
Old Oct 10, 2004 | 12:48 PM
Ok, since it is OBD-1 you will need to either jump it when the car is on or get one of those nifty code readers.
Old Oct 10, 2004 | 12:54 PM
jump it as in use the paper clip wen the cel turn on (dont you have to turn it off the car then put it in the on to start reading the code)
Old Oct 10, 2004 | 01:49 PM
DieMaster's Avatar
Needs to be About 20% Cooler
with the car off put the paperclip in then turn on the ignition not the engine. your CEL should blink ur code
Old Oct 10, 2004 | 07:30 PM
Default Re: cel problem, it turns on and off.... (DieMaster)
the cel light doesnt come back on when i turn the key on, it turns off..
well ill try that anyway just to see if it gives me a code..
Hill4589
Mar 1, 2009 09:02 AM
slvrlude
Dec 27, 2008 02:50 PM
lilpastrana
Feb 27, 2007 04:59 PM
CapnChunk
Mar 23, 2003 07:33 AM
