Skunk2 intake manifold problem i think
Old Oct 10, 2004 | 11:16 AM
duberz's Avatar
Default Skunk2 intake manifold problem i think
After i installed a skunk2 intake on my GSR, whenever i start my car, it idles at like 2500 rpm until the engine warmsup, i still have the stock throttle body and computer, is there a way to adjust this?
I dont think it's vacuum since it goes away after it warms up, but for sure the computer wants to increase the engine flow when cold which is harder with a single plain manifold now..
what do i do ?!? it's annonying as hell
Old Oct 10, 2004 | 12:19 PM
boosted k20's Avatar
Default Re: Skunk2 intake manifold problem i think (duberz)
whats the idle once it's warmed up? around 750?
Old Oct 11, 2004 | 01:17 PM
duberz's Avatar
Default Re: Skunk2 intake manifold problem i think (boosted k20)
yeah, idles there
Old Oct 11, 2004 | 01:49 PM
jar's Avatar
jar
Mine does the same thing, I'd like to know what's up.
BUMP.
Old Oct 11, 2004 | 01:54 PM
CA6VTEC's Avatar
<FONT COLOR="royalblue"> Sounds like you have an IACV problem. Did you try cleaning the iacv? I am going thru something similar. When the car is cold, it idles @ 1500rpm and once it warms up it goes down too 800rpm. </FONT>
Old Oct 11, 2004 | 02:01 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: Skunk2 intake manifold problem i think (CA6VTEC)
I thought that kind of idle was normal. Mine does it every time it's cold. It's a bone stock 99 LS, bought from Carmax with 65xxx miles, and now it has 76xxx. Did it from day one of my ownership. Maybe I just inherited the problem from a previous owner.
Old Oct 11, 2004 | 02:21 PM
B00ST2nR's Avatar
Default Re: Skunk2 intake manifold problem i think (marsbike)
Check ALL your vacuum lines. ALL of them. I remember having this problem too and I found out one of the vacuum hoses came loose.
Old Oct 14, 2004 | 01:30 PM
duberz's Avatar
Default Re: Skunk2 intake manifold problem i think (B00ST2nR)
well i fixed my problem, and apparently it happens to a lot of integra..
I took apart the FIT valve, fast idle thermo valve, it's mounted on the bottom side of the throttle body, cleaned it all up, remounted it and it runs smooth now.
hope it helps others, 96 and up integra, the fit and iac are a one piece, 94 on mine is separate.
Old Oct 14, 2004 | 03:03 PM
CA6VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duberz &raquo;</TD></TR><TR><TD CLASS="quote">well i fixed my problem, and apparently it happens to a lot of integra..
hope it helps others, 96 and up integra, the fit and iac are a one piece, 94 on mine is separate. </TD></TR></TABLE>
<FONT COLOR="royalblue"> nice! </FONT>
dj theoretic
Jan 2, 2009 07:45 AM
importdude2000
Mar 12, 2006 04:48 PM
iukaman420
May 4, 2005 02:56 PM
ncVTEC1313
Dec 22, 2003 01:49 AM
