are craftsman adjustable timing guns accurate?
Old Oct 10, 2004 | 10:14 AM
euclid's Avatar
Default are craftsman adjustable timing guns accurate?
im going to buy a timing gun but im alittle sceptical that an adjustable(dial type) would be accurate or even needed.
does anyone have any bad experience with a particular brand/style of light? thanks
Old Oct 10, 2004 | 10:15 AM
.RJ's Avatar
.RJ
Default Re: are craftsman adjustable timing guns accurate? (euclid)
I havent had any problems using a "dial" type.
Old Oct 10, 2004 | 10:20 AM
euclid's Avatar
Default Re: are craftsman adjustable timing guns accurate? (.RJ)
ok thanks, its sunday and i'm off to sears, advertizing has warped my mind.
Old Oct 10, 2004 | 12:59 PM
Mike K's Avatar
mine had been fine for almost 6 years. now the leads are getting kinda touchy. but hell, for a timing light purchased in 98, it has been good.
Old Oct 10, 2004 | 02:25 PM
euclid's Avatar
Default Re: are craftsman adjustable timing guns accurate? (Mike K)
this craftsman adjustable is accurate at 16deg, no worries
Old Oct 10, 2004 | 05:57 PM
Rene M's Avatar
Good stuff unless you have a MSD.. then your screwed, the timing light will fire on the first pulse which will cause you to set the timing advanced.. ( guess how i found that out)
Old Oct 10, 2004 | 10:35 PM
KayOs's Avatar
What's the model # of the timing gun you bought?
Old Oct 12, 2004 | 08:31 PM
euclid's Avatar
Default Re: are craftsman adjustable timing guns accurate? (KayOs)
http://www.sears.com/sr/javasr...CRAFT
Old Oct 15, 2004 | 05:29 PM
lsvtecracer's Avatar
I have a question about using the timing gun. When you set the dial **** to zero is it suppose to line up with the 16degree mark on the pulley?? Because when I put the dial **** to zero is line up with my 16 degree mark and when I advance it to 16degree on the ****, it line up with the 0 degree mark on the pulley?? Is it suppose to be like that? Thanks.
Old Oct 16, 2004 | 03:05 AM
DutchITR1689's Avatar
Default Re: are craftsman adjustable timing guns accurate? (lsvtecracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecracer &raquo;</TD></TR><TR><TD CLASS="quote">I have a question about using the timing gun. When you set the dial **** to zero is it suppose to line up with the 16degree mark on the pulley?? Because when I put the dial **** to zero is line up with my 16 degree mark and when I advance it to 16degree on the ****, it line up with the 0 degree mark on the pulley?? Is it suppose to be like that? Thanks.</TD></TR></TABLE>
yep.
Old Oct 16, 2004 | 09:41 PM
Default Re: are craftsman adjustable timing guns accurate? (DutchITR1689)
thanks for the reply
rhdins
Aug 25, 2008 07:26 PM
civic j
Aug 17, 2007 08:10 AM
xJDMCx
Sep 15, 2006 09:34 AM
Propulsion
Sep 18, 2004 06:56 PM
Magick211
Dec 11, 2001 04:29 PM
