vss wiring help
hey guys ive done the search and tried everyway that everyone has mentioned and still nothing. ive got a 96 ls cluster, with an 96 vss. black is ground, yellow/white is power, yellow/blue is signal. ive tried it all and still no vtec and no speedometer. WTF is going on please help if you can
im running a 91 hatch si
B16A obdo pr3 ecu
96 ls cluster with 96 vss
my question is the ground goes to black. the yellow/white goes to A15 on the ecu (power). and yellow/blue (signal) goes to the cluster and then to the ecu at B16. is this correct?
Modified by JDMHatch101 at 11:44 AM 10/10/2004
B16A obdo pr3 ecu
well Im not sure how you you wired up the signal wire but here is a little diagram I made that might help. The signal wire has to be split like a Y after it leaves the VSS. Run one end of the Y to the ecu and the other to the back of the cluster. Or maybe you have the power and signal wire switched.
-James-
-James-
yup its the same size and mine fits fine just alittle lose for now im going to make custom brackets for it. in the mean time its in there pretty good no worries about it falling out or moving alot. ill have pics up soon. ps how do i post pics on here?
Modified by JDMHatch101 at 8:32 PM 10/12/2004
efrex
14
Dec 5, 2006 05:01 PM
