DC seats in a EG coupe?
Well i have a 95 LS integra with a severe case of rod knock an some cosmetics issues... im about to buy a 95 EX coupe an i was just wondering if my DC seats will bolt up in the EG because i dont care for the stock seats an one of em has a burn hole... im new to the civic world and i couldnt seem to find anything when i searched... thanks alot in advance for the help too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94JDMEG »</TD></TR><TR><TD CLASS="quote">DC Integra seats are a direct bolt-on in EG Civic's.
only 3 of the bolts will fit though
</TD></TR></TABLE>only 3 of the bolts will fit though
not true! 4 bolts will fit. one of the drivers side seat brackets bolt location is a little tight fitting (was for me) but if you've done this before you would know. please dont post if you dont know what you are talking about.
<FONT COLOR="blue"> EDIT: see below</FONT>
Modified by 94JDMEG at 10:59 PM 10/10/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe »</TD></TR><TR><TD CLASS="quote">
only 3 of the bolts will fit though</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94JDMEG »</TD></TR><TR><TD CLASS="quote">not true! 4 bolts will fit. one of the drivers side seat brackets bolt loctaion is a little tight fitting (was for me) but if you've done this before you would know. please dont post if you dont know what you are talking about.</TD></TR></TABLE>
Actually egcoupe is correct. I also thought that they'd all bolt in perfectly, as this is what I saw with my own eyes, on a number of occassions, as well as what all of my friends noted when they did theres. However, when I went to Integra seats in my Civic, the passenger side, rear left bolt was off by about 3inches. My car, a 93 Si hatch, was the only one I had ever seen not fit, but my stock seats fit perfect. Taking the stock Civic seat and trying to line it up in the Integra, gave the same results, off by about 3inches in the rear left passenger bolt hole.
I recently aquired a Recaro for the passenger side, and a friend offered me his JDM DC2 passenger bracket and sliders so I wouldn't have to buy them. When I went to bolt it in, same exact problem, off by about 3 inches. I still don't know what the correlation is in years, but some don't fit exactly on the passenger side.
Taken from the General Rules and Guidelines of Posting:
<FONT COLOR="red">- If you post technical info, but are not 100% sure about the info please say so. Too many people post "factual" info when it is in fact, NOT so. This is as bad or worse than any other violation of the rules. By simply stating "I'm not 100%, but I think..." you can save someone a lot of trouble if they are working on their car based on your info.</FONT>
...egcoupe...no big deal..but if you didn't get all 4 bolts in you didn't even try...people need to know that infact these seats will bolt-in completely. it is unsafe to not be secured completely.
<FONT COLOR="blue">EDIT: it appears that i am only half-correct myself..well my 94 GS-R two door seats fit nearly perfectly into my 94 Civic DX two door..THAT I AM 100% SURE OF. any other combo i cannot guarantee and therefore apologize doubting.</FONT>
From: Why so you can pretend like youre interested, FL/OK
I know for sure 1998 rails as well as 1994 will fit. So someone can fit in the rest of the years, but I already know sometimes 3 of the 4 bolts line up. In those small cases, you switch the rails out to compensate for the problem.
My friend with a 95 ex coupe has dc integra seats and they bolted on all 4 bolts. No rail swapping needed. The ek civics however need the inside rail swapped (I had to do it with my gsr leathers in my 99 hatch.
Lets try not to mention EK in here, let's really get a list of which years have fit. What year seats were your friends?
BLeSR
Aug 2, 2010 09:59 PM
myflyintegra
Jan 14, 2009 02:19 PM
sohc1200cc
Jan 2, 2006 08:02 PM
drift9
Feb 1, 2005 02:04 PM
