a2 head on ep3. Can it be turboed or not?
Old Oct 9, 2004 | 11:16 PM
spontaneous ep3's Avatar
Default a2 head on ep3. Can it be turboed or not?
I am wondering if this is true or not. I heard that if swaping out the a3 for the a2 head on the ep3 that you cant turbo it. Can some one help me out because i am planing to do this swap and later turboing it.
Old Oct 10, 2004 | 04:31 AM
Kal's Avatar
Kal
Default Re: a2 head on ep3. Can it be turboed or not? (spontaneous ep3)
why not just get an entire a2 engine if you're going to so much trouble already.
you can run anything with good tuning.
Old Oct 10, 2004 | 07:54 AM
taikahn's Avatar
Lower compression of the A3 makes it a better candidate for turbo. DONT waste your money on a head or swap ... just turbo the a3.
Old Oct 10, 2004 | 11:26 AM
360's Avatar
360
Default Re: (taikahn)
If you swap for the a2 head, you'll have the lower compression of the a3 and the better flowing head of the a2. Is it worth it? Not in my opinion.
The a2 makes about 270whp at 7psi and the a3 makes that at 9psi. Instead of spending money on swapping the head, I'd get stronger pistons and rods.
Remember that the a3's pistons may be lower compression, but they also seem to be weaker than those of the a2.
Old Oct 10, 2004 | 12:14 PM
JMod's Avatar
Default Re: (360)
You'll be much happier just turboing your A3. The gains you'll get by swapping on the A2 head will not be worth the money spent.
Old Oct 10, 2004 | 02:14 PM
BaNAnABoAt689's Avatar
B A N N E D
From: los angeles, Eagle Rock, CA, united states of america
just do it i would say. if you have the money. having real vtec and having a low compression then what an k20a or a k20a2 would have. then be able to boost at higher psi. sounds good to me. but that will leave a hole in your pcoket
josh green
12
Oct 1, 2011 11:01 AM
BLU CIVIC
11
Nov 3, 2009 05:35 AM
sivtechatchy
Jul 10, 2008 07:14 AM
Y2A
Mar 4, 2005 09:03 AM
digital sol
Feb 1, 2005 07:58 AM
