i broke a bolt. what do i do
Old Oct 9, 2004 | 11:10 PM
yellowmonkeyboy's Avatar
Default i broke a bolt. what do i do
i was changing my brake pads on my 95 del sol si, and i tighted the bolt on too tight and it snapped off. How do i get the peice that is still inside. (i am talking about the bolt that is the only bolt you take off when changing brake pads)
Old Oct 9, 2004 | 11:23 PM
B2FiNiTY's Avatar
Default Re: i broke a bolt. what do i do (yellowmonkeyboy)
Drill it out.
Old Oct 9, 2004 | 11:34 PM
Default Re: i broke a bolt. what do i do (B2FiNiTY)
we tried drilling it out... didnt work... maybe it was the bit we were using... do you have any specifics on how exactly i drill it out? or have you done anything like this before?
Old Oct 9, 2004 | 11:39 PM
murmur9's Avatar
you could have someone weld a bolt on to it.....and then try and just loosen it out.
Old Oct 9, 2004 | 11:47 PM
Br1anPham's Avatar
Default Re: i broke a bolt. what do i do (murmur9)
Easy out.
Old Oct 9, 2004 | 11:55 PM
Calvinator's Avatar
Default Re: i broke a bolt. what do i do (Br1anPham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1anPham &raquo;</TD></TR><TR><TD CLASS="quote">Easy out.</TD></TR></TABLE>
Easy out extractor. I think thats what its called. Its basically a reversed bit. You drill a hole in the middle of the bolt, and slowly screw in the easy out bit. Worked on my engine mount bolt when it broke off.
Old Oct 10, 2004 | 06:10 AM
dwnthehatch's Avatar
Default Re: i broke a bolt. what do i do (xtremeazian)
https://honda-tech.com/zerothread?id=567450
LOWLIFEHATCH
25
May 18, 2023 07:14 AM
Birdley42008
Oct 1, 2007 03:35 PM
pburke23
Jun 4, 2004 10:00 PM
EL Vap133
Apr 6, 2004 11:44 AM
civicracer1993
Apr 18, 2002 07:50 PM
