type-r Cluster in a 00 hb
Old Oct 9, 2004 | 08:57 PM
98-integra's Avatar
Default type-r Cluster in a 00 hb?
will a type-r cluster fit into a 00 civic hb? i know i can make it fit, and that i will have some rewiring to do but i wanted to know if it will fit without cutting the dash?
Old Oct 9, 2004 | 09:01 PM
92RED Hatch's Avatar
Default Re: type-r Cluster in a 00 hb? (98-integra)
Try searching...there is alot of info on this exact subject. Just type in ITR cluster in ek/eg You'll find quite a bit
Old Oct 9, 2004 | 09:03 PM
98-integra's Avatar
Default Re: type-r Cluster in a 00 hb? (92RED Hatch)
thanks i couldnt find anything on it cause i was trying type-r cluster
Old Oct 9, 2004 | 09:10 PM
aberfoyle's Avatar
A Civic Type-R cluster will fit but not an Integra Type-R cluster.
Old Oct 9, 2004 | 09:11 PM
EricUSC's Avatar
Default Re: type-r Cluster in a 00 hb? (specki)
This may help:
http://patriot.net/~merritt/gauge.html
Old Oct 9, 2004 | 09:14 PM
98-integra's Avatar
Default Re: type-r Cluster in a 00 hb? (EricUSC)
lol EricUSC i just found that site, thanks guys for the help
Old Oct 9, 2004 | 09:27 PM
BlueIntegraBoy's Avatar
Good luck. I enjoyed putting an LS cluster in my friend's 00 Civic.
Old Oct 9, 2004 | 09:31 PM
98-integra's Avatar
Default Re: type-r Cluster in a 00 hb? (BlueIntegraBoy)
blueintegraboy by that do you mean is wasnt easy? from the little bit i've read on it , it doesnt seem like its going to be easy
Old Oct 10, 2004 | 03:22 AM
No, it's very easy to repin my friend's Civic harness using the Integra plugs. The site above has the pinouts. The only hard thing about it was how to depin the plugs. Took me a while to figure it out, after that it's a breeze. You'll only need to splice the ABS wires because the wires are flipped around on the Civic plug. Let me know if you need more assistance.
Old Oct 10, 2004 | 05:31 AM
98-integra's Avatar
cool thanks
strider1
Honda Civic (2001 - 2005)
Mar 10, 2009 09:43 PM
hondacivicjd
May 29, 2008 11:27 PM
Chynito_JDM
Oct 16, 2005 07:52 PM
