Glass Pistions!?
Old Oct 9, 2004 | 08:47 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Glass Pistions!?
what are Glass Bead Pistons? and waht do they offer comparied to normal pistions?
Old Oct 9, 2004 | 08:53 PM
Change's Avatar
Default Re: Glass Pistions!? (DieMaster)
no idea...
Old Oct 9, 2004 | 08:57 PM
mrspeaker's Avatar
Default Re: Glass Pistions!? (pSI civic)
Glass beading is a process,,like sand blasting or media blasting..its not a product
I have no idea what that has to do with pistons,,,DO U have a link???
Old Oct 9, 2004 | 09:01 PM
DieMaster's Avatar
Default Re: Glass Pistions!? (Mrspeaker)
yea it says "glass bead pistions" about half way down list
http://www.inlinefour.com/services.html
Old Oct 9, 2004 | 09:03 PM
davens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pSI civic &raquo;</TD></TR><TR><TD CLASS="quote">no idea...</TD></TR></TABLE>
way to contribute...
bead blasting with glass is for cleaning...
it can also be used for shot peening soft metals
Old Oct 9, 2004 | 09:05 PM
mrspeaker's Avatar
Well like I said its a stripping process like media blasing...or sand blasting etc..
Just call to find out about it........
Old Oct 10, 2004 | 03:55 AM
SETI20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Our "REFRESH" Bottom-End Package
Glass Bead Pistons
Simple clean up job.
Old Oct 10, 2004 | 05:38 AM
blah13's Avatar
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">
Simple clean up job.</TD></TR></TABLE>
Exactly, its simply how they would remove the carbon buildup on your pistons.
Old Oct 10, 2004 | 07:27 AM
4inspeed's Avatar
Default Re: (blah13)
dont know if there is any truth in it.... but i have heard that sand blasting your piston/rods... it relieves any stress from wera/tear they have accumulated. so it would almost be like reistalling "fresh" or new stock rods by simply sand blasting them.
like i said not sure if its true just something ive heard, any comments?
Old Oct 10, 2004 | 08:24 AM
blah13's Avatar
Default Re: (4inspeed)
Sounds like your referring to shot-peening, I'm sure theres a multitude of names for the procedure but yes, they use harder beads and at a greater velocity and it essetially "packs" the metal tighter and makes it stronger and the packing action fills in tiny tiny cracks and eliminates stress risers.
Glass beads as far as I know are used 100% as a cleaner, same with sand blasting. Shot peene uses metals, steel iron not sure the exact material.
Old Oct 10, 2004 | 08:36 AM
Bandit74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">Well like I said its a stripping process like media blasing...or sand blasting etc..
Just call to find out about it........</TD></TR></TABLE>
Old Oct 10, 2004 | 08:38 AM
Nic's Avatar
Nic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your referring to shot-peening, I'm sure theres a multitude of names for the procedure but yes, they use harder beads and at a greater velocity and it essetially "packs" the metal tighter and makes it stronger and the packing action fills in tiny tiny cracks and eliminates stress risers.
Glass beads as far as I know are used 100% as a cleaner, same with sand blasting. Shot peene uses metals, steel iron not sure the exact material.</TD></TR></TABLE>
Old Oct 10, 2004 | 09:04 AM
SETI20's Avatar
It uses Lead I believe...because of the mass, and characteristics. That way the surface doesn't get damaged.
Old Oct 10, 2004 | 09:11 AM
Mugen Dom's Avatar
only thing with shot peening is it shortens the life of the rods that u shot peen.....
Old Oct 10, 2004 | 09:21 AM
turboZChatch's Avatar
glass beading is like shot peening like someone said above they literally shoot the objects with a blast of tiny glass ***** which smooths the object out.....The advantage to this esp. on a piston is that all of the rigid edges and tiny pieces of metal that are slightly higher then the rest of the piston are takin away this is done to reduce posibility of detonation the smaller the piece the more likely it is to get hot the hotter the pistion is the more likely it is to melt or other things.......hope that helped
93Ls-tegra
Oct 25, 2006 08:10 AM
blackdude
Aug 3, 2006 11:11 PM
RedEj8
Apr 26, 2006 06:42 AM
Boostage
May 28, 2005 06:56 PM
Fatty_1775
Jul 6, 2003 10:45 PM
