Hole saws...
Quick question. What brand hole saws are you guys using to punch holes in manifolds for the wg? For the past few years we've just used the ones from Home Depot and they are only good for a manifold then are dead. Since our volume of fabrication has gone through the roof in the past few months we need to find a faster way of doing this.
Any ideas or comments are welcome, thanks
-bill
-bill
https://honda-tech.com/zerothread?id=1013754
and you can do alot more w/it! Just make sure you stuff the hell out of the backside of the hole, and clean up around the cut, otherwise welding is a chore(and weak).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_sb2000 »</TD></TR><TR><TD CLASS="quote">
If you have to use hole saws, slow them waaaaaay down. Like 150 rpm, and alot of rapid tap.</TD></TR></TABLE>
gave up on that **** a long time ago.
plasma cutter
i have a miller 30amp unit and i've never encountered anything it can't cut cleanly while doing automotive fab.
That is a SCREAMIN deal though ^
plasma cutter
*Boostwerks*
Welding / Fabrication
47
Jul 2, 2006 05:53 AM
