ctr piston or toda piston?
Old Oct 9, 2004 | 07:52 PM
JDM978's Avatar
Default ctr piston or toda piston?
hey was up guy im going all motor here on my EG with a itr engine i was wonder wats betta ctr pistons or toda forged piston at 82mm? which would give me a high compression? all inputs would be great here i always wanna know it will clear my head or do i have to horne it ? should the CTR jsut drop in with no modification to the head
Modified by JDM978 at 4:25 PM 10/10/2004
Old Oct 9, 2004 | 08:07 PM
EIT_certified's Avatar
Default Re: ctr piston or toda piston? (JDM978)
ctr pistons would give you a 10.8 compression, a jdm type r motor has a compression of 11.1 and a usdm has a compression of 10.6. I wouldn't suggest ctr's if you have a itr because of the cost for such a small gain and that's only if you have a usdm itr. if you are looking for significant compression gains look into Wiseco, JG, and Arias pistons
Old Oct 9, 2004 | 08:31 PM
JDM978's Avatar
thank for the suggestion will look further in2 it
Old Oct 9, 2004 | 08:35 PM
JdmEg6Hybrid's Avatar
and it depends on what block and head you have
Old Oct 9, 2004 | 08:43 PM
Default Re: ctr piston or toda piston? (JdmEg6Hybrid)
you know what i was wrong. the pct pistons (ctr's) will give you a compression of atleast 12.0 check out this link http://technet.ff-squad.com/cr-calculator.htm
Old Oct 9, 2004 | 09:03 PM
s0ulless's Avatar
I would settle with the ctr. What block and head do you have? set up?
Old Oct 10, 2004 | 06:56 AM
b19coupe's Avatar
CTR pistons are about $300 and you can use stock rods with no modification. Toda pistons are about $800 and require machining the rods to work. If $$ are a consideration, then the choice is clear.
Old Oct 10, 2004 | 10:31 AM
JDM978's Avatar
Default Re: ctr piston or toda piston? (s0ulless)
im going wit a b18c5 block & type r head which i got toda spec b cam shaft & toda cam gear. need to know if eagles rods will work fine with the ctr piston cause a local shop told me it wont work were thy connect together that i should stick with my itr rods or go with a different piston can any 1 help me here
Modified by JDM978 at 10:08 PM 10/10/2004
Modified by JDM978 at 2:29 PM 10/30/2004
johnzm
566
Mar 19, 2013 05:13 AM
Robs_B18c
22
Oct 6, 2005 06:05 PM
RicTRD
Sep 16, 2005 03:46 PM
00BlackDc2
Feb 22, 2004 12:13 AM
bframe
Mar 3, 2003 12:52 PM
