Pro/Cons to removing front fender liner?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS till 4K »</TD></TR><TR><TD CLASS="quote">dirty engine bay/door jams</TD></TR></TABLE>
So true. I was in a little fender bender driverside fender liner got ripped of.
Now dirts and crap into the front of doors.
I need a driverside fender liner
this may be stupid, but also if you drive in snow and sand, it's alot more noisey because now all that shat hits metal instead of plastic...
-Mike
-Mike
what kinda suspension u running? i know some ppl with cheap springs and stock shot shocks that do the same thing cuz there car rolls too much through turns, maybe if u had better shocks/springs it wouldnt rub
Especially if you run into construction where theres rubbles of loose dirt. That **** will hit everywhere and you will hear nasty noises from the inside.
It would also SLIGHTLY affect the aerodynamics of your car at high speeds resulting in a somewhat lower miles/gallon.
I've had no liners for more than 3 years and I've listed my problems. Other than that, if you're really slammed and don't want to bust up your current ones due to rubbing then leave em off. I'm used to it so it's no biggie to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 »</TD></TR><TR><TD CLASS="quote">look out for water spray from the tire onto the filter if you have a cai, could get dangerous. </TD></TR></TABLE>
I forgot to mention that...
I used to run a cai too and when it rained...it pretty much sucked in some water...car was sluggish as hell...
But I managed to get the water out...
Fuel Injector cleaners/Chevron Techron ...they all helped.
I made the mistake of taking out my fender liners. It helps if you have a lower car because it won't rub, but you can pick up rocks and chip the paint from the inside of the fender causing little star like dents. I am looking for new ones now.
well since nobody has said it so far. if you have a cai on your car and the liner is removed. most theives can and will jack your filter. pretty stupid but it happens espcially to my friend's ride. thieves=
crazy eyez killa
Aug 25, 2004 04:20 AM
