Would the engine idle real low and have slow pick up with a bad tps?
Old Oct 9, 2004 | 05:04 PM
kholmes's Avatar
Default Would the engine idle real low and have slow pick up with a bad tps?
While dropping the motor in the tps sensor broke off a bit. I soldered the wires on and when starting the car it runs real low like 200 rpms and when gasing it it takes a while to pick up. Is this the TPS sensor not working? Thanx
Old Oct 10, 2004 | 06:27 PM
civic-4-ges's Avatar
Default Re: Would the engine idle real low and have slow pick up with a bad tps? (kholmes)
It could have been moved slightly when you hit and broke it, causing the incorrect voltage at closed throttle. It most likely could use a calibration.
Old Oct 10, 2004 | 08:03 PM
kholmes's Avatar
Default Re: Would the engine idle real low and have slow pick up with a bad tps? (civic-4-ges)
How do you calibrate?
Old Oct 10, 2004 | 09:04 PM
93lsd's Avatar
get a multi meter and set it in volts and with the middle wire on the tps connected to the red wire on the multi meter and black wire on the multi meter connected too ground at idle you should have .4-5 volts with the key on in the #2pos and at wide open throttle you should have 5 volts... if not it is out of calibration is so just unscrew the two screws and move it till it is in calibration.
Old Oct 11, 2004 | 10:30 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
i thought that TPS' were rivited to the thottle body...
Old Oct 11, 2004 | 05:53 PM
PrettyLude's Avatar
they are on some of them, just cut the rivets off with a die grinder and replace the rivets with some screws
Old Oct 11, 2004 | 08:57 PM
kholmes's Avatar
Default Re: (PrettyLude)
I have another tb with the tps coming but the thing is Im ot throwing any codes.
Old Oct 12, 2004 | 06:59 PM
kholmes's Avatar
Default Re: (kholmes)
Anyone else know what it could be, ive checked around for stuff wrong but cant figure this out. Im using a 96-98 wire harness and ecu on a 00 motor. All plugs on the harness will pretty much only clip into one sensor right?
giddyup21
Mar 18, 2012 06:49 PM
949
Aug 1, 2008 08:20 AM
93CX
24
Apr 15, 2005 07:14 PM
snouka
Oct 15, 2004 02:02 PM
soHybridized
Mar 13, 2002 10:22 AM
