main relay
Old Oct 9, 2004 | 03:41 PM
mbdelsol's Avatar
Default main relay
my car start fine, When the car is running every few sec the main relay will click so power is loss and rpm drops. then it click again and rpm goes up. Could this be bad relay or faulty ground or power> any ideas?
Old Oct 10, 2004 | 02:10 PM
mbdelsol's Avatar
Default Re: main relay (mbdelsol)
help
Old Oct 10, 2004 | 07:53 PM
Bandit74's Avatar
Had anything been done to the car before this started?
Old Oct 10, 2004 | 08:44 PM
mbdelsol's Avatar
Default Re: main relay (Bandit74)
i install a resistor box. but i have check and double check connection making sure nothing short to ground or anything
Old Oct 10, 2004 | 10:23 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bandit74 &raquo;</TD></TR><TR><TD CLASS="quote">Had anything been done to the car before this started?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbdelsol &raquo;</TD></TR><TR><TD CLASS="quote">i install a resistor box. but i have check and double check connection making sure nothing short to ground or anything</TD></TR></TABLE>
Why did you install the resistor box? Swap or did yours fail.? Need more info.
Old Oct 11, 2004 | 10:00 AM
mbdelsol's Avatar
Default Re: main relay (eda6 hatch)
my car consist of
b16a built bottom end
gsr head
t3/t4 turbo
running uberdata
i install a resistor box because i had some radio shack resitor that where not working to well. im running some dsm injectors.
sitinthehall
Sep 12, 2007 05:41 AM
b20vtec crx
Oct 8, 2005 02:49 PM
mp5o
Aug 5, 2005 07:44 PM
boi_si
17
Dec 14, 2004 03:47 PM
HatchBox
Oct 22, 2004 07:37 PM
