Safest way to clean engine wireharess covered in thick amounts of oil
Old Oct 9, 2004 | 11:47 AM
Silver_Rex's Avatar
Default Safest way to clean engine wireharess covered in thick amounts of oil
Just as the title states I need to find out what is the safest way to clean a wire harness. My friends valve cover on his 91 si cracked for some reason and was spewing oil all over the motor and wire harness. I removed the wire harness from the motor and would like to clean it up, but im not sure what steps or a way to wash the harness without messing it up.
I was thinking of using my pressure washer (low setting) to hose it down. Just not sure if I will damage it in any way?
Any one have any ideas?
Mig
Old Oct 9, 2004 | 11:52 AM
HXMan's Avatar
Default Re: Safest way to clean engine wireharess covered in thick amounts of oil (Silver_Rex)
Hmmm....try brakeclean.
Old Oct 9, 2004 | 11:59 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Safest way to clean engine wireharess covered in thick amounts of oil (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm....try brakeclean.</TD></TR></TABLE>
Not on wires/plastic....
Old Oct 9, 2004 | 12:05 PM
HXMan's Avatar
Default Re: Safest way to clean engine wireharess covered in thick amounts of oil (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Not on wires/plastic.... </TD></TR></TABLE>
Yea, it is bad on certain plastics.
Old Oct 9, 2004 | 12:10 PM
Fobtions's Avatar
simple green automotive
Old Oct 9, 2004 | 12:12 PM
]{iwi's Avatar
Default Re: Safest way to clean engine wireharess covered in thick amounts of oil (Fobtions)
^^^ agreed
Old Oct 9, 2004 | 01:08 PM
Silver_Rex's Avatar
so simple green it then hose it off with water?
ok..
Old Oct 9, 2004 | 01:15 PM
HXMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver_Rex &raquo;</TD></TR><TR><TD CLASS="quote">so simple green it then hose it off with water?
ok..</TD></TR></TABLE>
Yes, that is how I did it with my car. But I also had compressed air ready to blow off the electrical components, and I did cover some things like the distributor.
Old Oct 9, 2004 | 04:10 PM
b20vtec+boost=v8 killa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">simple green automotive</TD></TR></TABLE>
Old Oct 9, 2004 | 04:26 PM
Silver_Rex's Avatar
The wireharness have been completely removed from the car. Its sitting on my garage floor. When i rinse it , im more concerned on the plug ends since they are exposed and not connected.
Mig
Old Oct 9, 2004 | 04:44 PM
88 rex's Avatar
I would wrap the plugs in plastic and use engine cleaner, something like simple green, and spray down the wires. That should cut through any junk on the wires.
Old Oct 9, 2004 | 04:54 PM
Fobtions's Avatar
Default Re: Safest way to clean engine wireharess covered in thick amounts of oil (88 rex)
you can spray the plug ends , make sure u shoot some compressed air in there, how else will you get teh harness to bling. and pack it with some electrical grease
Old Oct 9, 2004 | 07:03 PM
TheSSG's Avatar
They Do make an Electrical Component Cleaner...won't damage anything, works dang well...
Old Oct 9, 2004 | 07:11 PM
NCRXSi's Avatar
Default Re: Safest way to clean engine wireharess covered in thick amounts of oil (TheSSG)
With harness off the car you have half the battle won! As everyone else said, soak it with some simple green, get a scrub brush or rag and clean it up. Even if you don't have a compressor to blow the water out of your plugs I'm sure hanging it up and letting it air dry will be fine.
Old Oct 9, 2004 | 09:00 PM
Silver_Rex's Avatar
Default Re: Safest way to clean engine wireharess covered in thick amounts of oil (NCRXSi)
Cool thats all i Needed to know.. thanks for the help..
Mig
tyler100
14
Nov 5, 2008 02:56 PM
MattsGreenEG
Sep 26, 2007 08:01 AM
dtec
Aug 7, 2007 12:04 PM
PA MATT
Feb 19, 2007 09:18 PM
eg6cvchatch
Jun 8, 2005 05:28 AM
