speedometer and vtec... and vss
Old Oct 9, 2004 | 08:55 AM
hndakd's Avatar
Default speedometer and vtec... and vss
my speedometer still doesnt work. i have tried to run a wire directly from the vss to the cluster and its still a no go. i looked at the back of the cluster where that green thing is and looks fine but in all honesty dont really know what im lookin for, everything seems to look like its still connected. i know the speed sensor is workin cause i have it wired directly to my ecu and vtec is still makin first chirp. any help is most appreciated.
car is 98 ex
b18c1
dash swap(i wired everything correctly it worked before)
Old Oct 11, 2004 | 07:16 PM
frostcivic's Avatar
Default Re: speedometer and vtec... and vss (hndakd)
i have the same problem i can't tell how fast i'm going. so i swapped the sensor and it is still messed. i was told it could be my cluster. why don't you look for a working cluster swap it and see if that works.
Old Nov 15, 2004 | 10:32 AM
hndakd's Avatar
Default Re: speedometer and vtec... and vss (frostcivic)
tried that and it still doesnt work. now im using an aftermarket speedo and it still doesnt work
Old Nov 15, 2004 | 10:55 AM
IWearMyKswiss's Avatar
New User
have you tried another VSS? are you throwing a code?
Old Nov 15, 2004 | 11:01 AM
klungemonger's Avatar
The VSS has nothing to do with activating VTEC. Sounds like a VSS problem, loose ground, or speedo is bad. VSS is very easy to change, find a friend with a good working one and swap it for a couple minutes to see what happens. Just one bolt right on top the tranny and it pulls right out.
Old Nov 15, 2004 | 07:57 PM
hndakd's Avatar
Default Re: (klungemonger)
yes the sensor is brand new from acura.
vtec is activated only when the car is moving....
Old Nov 16, 2004 | 03:21 PM
97VtecIN's Avatar
Default Re: (hndakd)
Not to jack the thread or anything but I just had this problem, it still isn't fixed. The night before my VSS stopped working I ran side by side with my friend who has a 95' EX with CAI, Header, Exhaust and now he stomps my *** every time... we have raced a lot so I know there is something wrong so does the VSS really not have anything to do with VTEC? Hope you get your problem fixed man.
Old Nov 16, 2004 | 03:29 PM
freakin_eLRoD's Avatar
check fuse 15 under the dash. I had this problem along with an o2 problem when the o2 sensor wires got caught on the axle and ripped them. after fixing the o2 problem i continued to have a vss and vtec problem. heres the thread that i figured it out... https://honda-tech.com/zero...thank god for a helms )
Old Nov 16, 2004 | 03:52 PM
IVI's Avatar
IVI
Default Re: speedometer and vtec... and vss (powerBan.est1990)
does your cruise control work?
if your cruise control works it is not the vss.
Old Nov 16, 2004 | 03:57 PM
doublejz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger &raquo;</TD></TR><TR><TD CLASS="quote">The VSS has nothing to do with activating VTEC. Sounds like a VSS problem, loose ground, or speedo is bad. VSS is very easy to change, find a friend with a good working one and swap it for a couple minutes to see what happens. Just one bolt right on top the tranny and it pulls right out.</TD></TR></TABLE>
If the vss is bad sometime you will not be able engage vtec. For you that don't believe this, unhook the vss harness you wont have vtec.
http://info.honda-tech.com/ind...oting
just swap out the vss
wstef
Jul 14, 2007 06:22 PM
pundagreat
Sep 25, 2006 11:13 PM
Xtian8
14
Jul 28, 2005 09:00 PM
7mgtemk3
Feb 21, 2005 05:09 PM
dcrbin22
Oct 17, 2004 10:13 AM
