gsr in a civic swap problem
Old Oct 8, 2004 | 09:59 PM
beav's Avatar
Default gsr in a civic swap problem
hey guys, im swapping a 99 usdm gsr motor into a 00 civic ex. im having difficulty with the wiring because i didnt realize thatthe car was obd2b and the gsr was obd2a. first of all the computers are totally different in plugs, so i got an obd2b computer...fine...i still cant get the car to crank... i suppose its the car-harness thats not matching up with the motor harness, has anyone ever had this problem before? i dont think its something a "jumper harness" can fix so please, if anyone of you guys is serious, help me out, thanx
Old Oct 8, 2004 | 10:38 PM
Kendall's Avatar
We need more specific details. Have you checked to see that you're getting fuel? What about spark? Is everything grounded correctly? Did you double check to make sure everything is plugged in? Have you considered the fact that maybe your OBD-2B ECU might have an immobilizer that will need to be removed?
There are endless possibilities. We need more details. You may also want to try the "Hybrid" forum.
Old Oct 8, 2004 | 11:52 PM
DOHCtorTHRUST's Avatar
Default Re: (Kendall)
i got my money on the immobolizer....
Old Oct 9, 2004 | 05:56 AM
b19coupe's Avatar
Default Re: (DOHCtorTHRUST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtorTHRUST &raquo;</TD></TR><TR><TD CLASS="quote">i got my money on the immobolizer....</TD></TR></TABLE>
Ditto.
Old Oct 10, 2004 | 08:01 PM
beav's Avatar
Default Re: gsr in a civic swap problem (beav)
thanx guys, it ended up being a wierd distributor wiring problem....just messed around withit for a while, got the car on the road though.
Old Oct 10, 2004 | 08:34 PM
paulwelican's Avatar
thats weird because i did the same swap to my friends car and we had to wire up the crank flunktuation sensor and knock sensor...good job tho if it works
BK2
Apr 29, 2013 08:11 AM
trucksandtoys26
Nov 22, 2009 09:16 AM
sant0r0
Aug 13, 2005 06:02 PM
boostedblack99
Jan 26, 2003 02:54 PM
