i'm thinking of getting these.......
Old Dec 15, 2001 | 08:25 AM
Hukd Up's Avatar
Default i'm thinking of getting these.......
http://cgi.ebay.com/ebaymotors/aw-cg...170591&r=0&t=0
what do you guys think? are these the polyurethene ones which will make shifting more crisp?
thanx.
jason
Old Dec 15, 2001 | 10:03 AM
Hukd Up's Avatar
Default Re: i'm thinking of getting these....... (out_a_bounz)
i just noticed, it says del sol 88-00.....thats kinda off.......but anywayz.....
r these good? do any of the shop owners on the board have anything similar on stock? (i'd rather have the funds go to a member!)
Old Dec 15, 2001 | 10:48 AM
owen_the_soyboy's Avatar
I dunnop if they will make a big difference on a newer car, especially an ITR.
now on my 94 GSR they made a world of difference.
but those shifter bushings were beat up from many years of abuse and all season use.
Old Dec 15, 2001 | 11:08 AM
non-VTEC's Avatar
i have enengy suspension's shifter bushings and they work really well. they really give the shifter a more positive persice feel when shifting........
those neuspeed bushings look the same and probably work the same as the energy suspension bushings......
Old Dec 15, 2001 | 11:11 AM
Hybrid ctr's Avatar
Default Re: i'm thinking of getting these....... (non-VTEC)
Mugen bushings are only $55
Old Dec 15, 2001 | 11:24 AM
typerlover's Avatar
New User
Default Re: i'm thinking of getting these....... (Hybrid ctr)
How hard are these to install?
Old Dec 15, 2001 | 12:42 PM
Jason's Avatar
these are the same as the ES ones that I have...you can get them from http://www.summitracing.com for like 10 bucks, but they have a 6.95 handling charge w/ each order, so if you don't need anything else, it's kind of a waste...
I got mine there, but I agree w/ supporting the board sponsors, and they don't carry them, that's how I was directed to summit.
as far as installation, it's much easier to remove the shifter assembly to pop the front bushing on...takes 3 seconds w/ it off, I tried w/ it on and it was a bitch...
Old Dec 15, 2001 | 12:56 PM
EleanoR's Avatar
Default Re: i'm thinking of getting these....... (typer98)
Yes these shifter bushings can be had for $17 including shipping (ES ones) from Summit Racing. Installation was a bitch but i got them in. They do make the shift more precise and crisp for sure. Stock bushings are so flimsy compared to these.
Mike
Old Dec 15, 2001 | 01:18 PM
Kamil's Avatar
Default Re: i'm thinking of getting these....... (talkie25)
Get the ES ones.
I had the ES ones w/ C's short throw... awesome combo, I think the bushing made a bigger diffrance than the short throw.
Old Dec 15, 2001 | 01:21 PM
typerlover's Avatar
New User
Default Re: i'm thinking of getting these....... (Kamil)
Hmm, I'm still unclear on the installation of these. Can anyone give any more detailed instructions on how to do it?
Old Dec 15, 2001 | 03:02 PM
Tommy_Gunns's Avatar
Default Re: i'm thinking of getting these....... (typerlover)
installation is fairly simple...just make sure you use the grease that comes with the bushings as the bushing that goes bolts onto the tranny is a bitch to put on.
I would say it's easier than putting on a short shifter.
Old Dec 15, 2001 | 06:10 PM
fsarfino's Avatar
Read directions that come with the kit
as for the bushings buy the set for the entire car from energy sus. its only like 110.00 or so and comes w/ the shifter bushings but beware the install is a bitch oh and if you do the entire car do not forget to get a alignment after installing..
Old Dec 16, 2001 | 01:35 AM
Ch33se's Avatar
New User
Default Re: i'm thinking of getting these....... (dohcvtec16)
hey,
You people with the ES brushings, do you feel that it is harder to upshift "quickly" into 2ed gear? eversince i had the ES shifter brushing i had grind 2 many times. Needless to say i put the stocks back it and i havent grind 2ed once in 3 months.
Old Dec 16, 2001 | 01:42 AM
Type Goch's Avatar
New User
if you look under your car youll see the stock shift bushings. One at the beginning of the shiftlinkage and one at the end. Have a socket wrench by you so you can take the nut off the linkage. Take the stock bushings off, lube up the aftermarket ones and put em on. It's pretty simple but takes a little elbow grease.
Old Dec 16, 2001 | 10:19 AM
Hukd Up's Avatar
Default Re: i'm thinking of getting these....... (Type Goch)
thanx guys, i'm gonna go to crappy tire and see if they have the ES bushings in stock, if not, i'l prolly order them from summit!
jason
x_tuh_sy
Dec 8, 2007 12:03 PM
jumai182
26
Nov 15, 2006 02:29 PM
an2ny888
May 24, 2004 06:14 PM
elevatethis
23
Dec 28, 2003 01:51 AM
92CIVICCX
14
Jan 8, 2003 11:57 PM
