vafc question
Old Oct 8, 2004 | 08:02 PM
1slohatch's Avatar
Default vafc question
I'm trying to install a vafc-1 on a non-obd b16a with a pr3 ecu. I can't get a signal for pressure. I have it wired to pin c09, input and output are wired correctly, also ecu isnt throwing any codes, any suggestions
**edit*** found a discrepency from hybrid honda's pinouts vs hondata's pinouts for the pr3 ecu. hybrid honda's pinout http://tech2.hybridgarage.com/...pr3_a
says c9 is the only pressure source, hondatahttp://www.hondata.com/techwiringpw0.html says c11 is the correct source while hybrid says its a ground. Also c11 agrees with apexi's documentation so i will try c11 tomorrow and see if it works.
*edit2* c11 is the correct pin for the pr3 if you want to be sure test it with a multimeter before you cut it should read 2.5 volts(DC) with engine off and igniton on
Modified by 1slohatch at 1:20 PM 10/9/2004
Old Oct 8, 2004 | 09:07 PM
Kendall's Avatar
There are plenty of good wiring diagrams here on Honda-Tech. Search and you shall find. Let us know how C11 goes.
evoX2
Jul 23, 2005 08:53 AM
STREETWERKZ
Mar 25, 2005 08:22 PM
marieT1GRL
Mar 12, 2004 03:11 PM
UncleBen'sRacing
Mar 3, 2003 02:34 AM
