ZC tranny in Si ok or no?
Old Oct 8, 2004 | 07:38 PM
user 98292739's Avatar
Default ZC tranny in Si ok or no?
will a ZC tranny just bolt right on to my d16a6? i need a new transmission and i found a cheaper ZC. someone told me they are about the same preformance is this so? thx
Old Oct 8, 2004 | 07:58 PM
Change's Avatar
Default Re: ZC tranny in Si ok or no? (locovirus)
it will.
Old Oct 8, 2004 | 08:12 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Some zc trannys will, some won't. Which one are you talking about?
Old Oct 8, 2004 | 08:24 PM
crxdx89's Avatar
all zc trannies work
Old Oct 8, 2004 | 09:00 PM
Default Re: (crxdx89)
ZC transmission from a 1990 Honda CRX SI JDM Model w/ Intermediate Shaft?? and would there be any performance gains at all? or a decline in performance?
Old Oct 8, 2004 | 09:21 PM
Krakkles's Avatar
Default Re: (locovirus)
No performance change. Less torque steer, though.
Old Oct 8, 2004 | 09:27 PM
bummster's Avatar
Default Re: (Krakkles)
you'll find that the 4 to 5 shift will feel like you haven't gone up a gear at all... 1-2 is very tight and nice. 2-3-4 kinda spread out, and 4-5 so tight it's ridiculous. that's what my buddy says about his zc tranny. if you can, swap in the si final drive into the zc tranny.
you get the nice option of equal length axles too.
Old Oct 8, 2004 | 11:03 PM
rasta420's Avatar
Default Re: (bummster)
which axles can you use for the ZC tranny if you dont have the JDM ZC axles?
Old Oct 9, 2004 | 06:11 AM
so wait...can i use my Si axles? is it completely bolt on i don thave to change anything? all ZC are jdm right? i just dont want to take everything apart and find out i need new axles or new something to make it fit
Old Oct 9, 2004 | 06:40 AM
Bserieskllr's Avatar
just put your si final drive in the zc trans and you will have some nice gears.
Old Oct 9, 2004 | 08:12 AM
tjbizzo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdx89 &raquo;</TD></TR><TR><TD CLASS="quote">all zc trannies work</TD></TR></TABLE>
Um...NO! All ZC trannys DO NOT work! The ones that fit 86-89 Integras won't bolt up to a 88+ Civic/CRX bellhousing and the starter bolt up either. Please get your facts right before posting next time.
Old Oct 9, 2004 | 09:58 AM
4potnick's Avatar
Default Re: (tjbizzo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjbizzo &raquo;</TD></TR><TR><TD CLASS="quote">Um...NO! All ZC trannys DO NOT work! The ones that fit 86-89 Integras won't bolt up to a 88+ Civic/CRX bellhousing and the starter bolt up either. Please get your facts right before posting next time. </TD></TR></TABLE>Well. 86-89 integra is not a zc. ALL ZC TRANNY"S WILL BOLT UP. other dohc 1.6(86-89 integras) will not. ZC swap anyone?
Old Oct 9, 2004 | 10:09 AM
rasta420's Avatar
Default Re: (rasta420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasta420 &raquo;</TD></TR><TR><TD CLASS="quote">which axles can you use for the ZC tranny if you dont have the JDM ZC axles?</TD></TR></TABLE>
Old Oct 9, 2004 | 11:41 AM
tjbizzo's Avatar
Default Re: (4potnick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick &raquo;</TD></TR><TR><TD CLASS="quote">Well. 86-89 integra is not a zc. ALL ZC TRANNY"S WILL BOLT UP. other dohc 1.6(86-89 integras) will not. ZC swap anyone?</TD></TR></TABLE>
Wrong again! There were jdm dohc zc trannys that fit 86-89 jdm integras, 86-87 civics/crxs, and some other weirdly named jdm-only vehicles that DO NOT BOLT UP TO 88+ USDM CIVIC/CRX ENGINES! They ARE zc trannys! They DO NOT bolt up to most d-series engines! If you don't believe me then search ...
http://www.thezcresource.com/
http://www.cr-x.org/home/
http://crxresource.org/modules.php?name=Forums
http://www.honda-acura.net/forums/
http://www.superhonda.com/forum/
http://www.hondaswap.com/
http://hometown.aol.com/nosajuf/nosajuf2.htm
http://www.hasport.com/News/Ar...r.htm
http://dmoore.com/crx/zc.htm
http://www.geocities.com/teamp....html
http://www.geocities.com/teamp...c.htm
http://hometown.aol.com/nosajuf/nosajufa.htm
There, that should give you a start. Like I said before, do your homework and get your facts straight before you post, especially if someone has already corrected the same misinformation in the same thread. Read the original post. He doesn't say WHICH zc, just A zc that someone is selling cheap. Why would they sell it cheap? Maybe because it might not fit anything. I have no idea which one he is thinking of buying, it *might* fit, but I still think I should warn him that not all zc trannys fit and to make sure it's the right one before he buys it. Stop posting BS and I'll stop correcting you, mmmkay?
Old Oct 9, 2004 | 12:09 PM
ok pleaes stop argueing children. and thx for the look out TJ. but the tranny came from 1990 Honda CRX SI JDM. here damn it here is the ebay page http://cgi.ebay.com/ebaymotors...=WDVW now will this bolt up to everything in a 91 crx Si US version....i dont want to put it in and then noticed that i need to buy new parts or mod some parts... thx guys
Old Oct 9, 2004 | 12:10 PM
oh yea i dont know how to swap out geras...
Old Oct 9, 2004 | 12:18 PM
jdmoutlaw's Avatar
89 teg axles will work.
Old Oct 9, 2004 | 03:55 PM
Targa250R's Avatar
be professional
Make sure you get the intermediate shaft with the ZC transmission, because you will need it. From what I have read, you cannot use DX/Si axles.
The proper axles to use with a ZC trans and intermediate shaft in a G4 Civic are '90-93 Integra axles (not '86-89 Integra axles!).
Old Oct 10, 2004 | 02:51 PM
the tranny comes with intermediate shafts. and you said i cant use my axles with a ZC transmission even w/ the shaft? or do i need to get the teg axles? car=91 crx Si...seems like i should just stick with the Si tranny to keep troubles down...
Old Oct 10, 2004 | 02:54 PM
and is the 89 crx Si tranny the same as teh 91 tranny? sorry for the noob questions
Old Oct 10, 2004 | 03:37 PM
sparks performance's Avatar
it will bolt in with no problem,but the diff uses a larger inner spline so the stock axles will not work.i swapped a si diff into my zc and it works perfect
Old Oct 10, 2004 | 08:18 PM
rasta420's Avatar
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
The proper axles to use with a ZC trans and intermediate shaft in a G4 Civic are '90-93 Integra axles (not '86-89 Integra axles!).</TD></TR></TABLE>
can you use the 90-93 integra intermediate shaft if you dont have the ZC intermediate shaft? and which model integra would i order the parts from? GS? w/o ABS right?
thanks
Old Oct 13, 2004 | 10:09 PM
MugenFlaredCRX's Avatar
it will work but you need 88-89 teg axles
Spazius
Jun 16, 2007 02:03 PM
jetpilot
Oct 23, 2005 08:19 AM
h22_crx
Aug 30, 2005 05:59 AM
D-series ninja
Oct 1, 2004 06:10 PM
VELOCITY R
Sep 4, 2003 05:37 AM
