What's that noise?
Old Oct 8, 2004 | 07:13 PM
midgarr30's Avatar
Default What's that noise?
I have a 1998 Civic 4 door LX (4 cylinder). It's started to make noise from the engine area. It's like a low grumbly noise. It hasn't done this for the past 4 months. I went to a body shop and they said that it was the suspension (they specialize in suspensions, and it's definitely an engine noise, so i don't believe them). Please send me any information on this subject. Thank you.
Old Oct 8, 2004 | 07:15 PM
ej1 pilot's Avatar
Default Re: What's that noise? (midgarr30)
what kind of noise is it?, what area of the engine, the trans? we need a lot more info to help you
Old Oct 8, 2004 | 07:18 PM
midgarr30's Avatar
Default Re: What's that noise? (Art In Motion)
It's sounds like it's coming from the tranny. Like if I press hard on the throttle, the noise gets very loud and then when i let off but not all the way off, it sounds like a light grinding noise (kinda like a clutch not grabbing). I'm thinking it might be the cat too? is the cat located in the engine bay or in the undercarriage?
Old Oct 8, 2004 | 07:20 PM
ej1 pilot's Avatar
it could be either the heat shield or your main input shaft bearing, with your luck it will be the heat shield...jack or lift your car up and hit your exhaust (make sure its cooled) and see if it rattles, if it does find which piece of metal is shaking and tear it off with some snips the bolts will be too rusted
Old Oct 8, 2004 | 07:22 PM
midgarr30's Avatar
I watched and listented when the body shop workers hit the exhaust system. I didn't hear any rattling.
Old Oct 8, 2004 | 07:24 PM
ej1 pilot's Avatar
then its probably the IS bearing...does it stop when you push the clutch in? can you only hear it in 1-3rd gears?
Old Oct 8, 2004 | 07:25 PM
midgarr30's Avatar
It's an automatic, (i said it sounded LIKE a ungrabbing clutch). the input shaft meaning the crank?
Old Oct 8, 2004 | 07:30 PM
ej1 pilot's Avatar
nvm auto trannies dont have IS bearings, i dunno i give up
Old Oct 8, 2004 | 07:32 PM
midgarr30's Avatar
alrighty, thanks anyway
anyone else with any help?
1clean01
Honda Civic (2001 - 2005)
May 2, 2012 08:11 PM
HondaScott
Oct 25, 2006 11:48 PM
turbo01LS
Jan 23, 2005 11:24 AM
.MilanoRex
13
Sep 15, 2003 06:20 PM
Ibuprofen
Jan 10, 2002 03:51 AM
