4x114 Swap?
Old Oct 8, 2004 | 06:40 PM
JohnnieChimpo's Avatar
Default 4x114 Swap?
Please don't flame.
Lately I've been thinking of converting to the 4x114 setup.
I really like the one style of Prelude wheels and I'd like to run the 11" (4x114) Prelude brakes on the front.
Is there any way to convert the car over?
Old Oct 8, 2004 | 06:50 PM
HatchBox's Avatar
Skoobie no more...
Default Re: 4x114 Swap? (JohnnieChimpo)
just have a machine shop drill out the prelude rotors to 4x100 and then run 92 Accord cailers
see this thread for more details (pages 11+)
https://honda-tech.com/zerothre...ge=11
Evil Drew M is using that setup on his type R. But that is a track car
Not sure about daily driving. with that set up
Old Oct 9, 2004 | 11:01 AM
Default Re: 4x114 Swap? (HatchBox)
I understand what you are saying but I still couldn't run Prelude wheels.
I have the Accord Wagon calipers and I am able to machine rotors to 4x100
but the wheels......
Old Oct 9, 2004 | 11:04 AM
HatchBox's Avatar
Skoobie no more...
so thats the only reason you want to covert to 4x114?
Sounds like a awful lot of work just to run a set of rims,
But whatever floats your boat.
Maybe try to find some prelude knuckles and rear trailing arms,
Not sure if they will work right or not.
Old Oct 9, 2004 | 11:06 AM
HumanResource's Avatar
Need to swap over Hubs to run any other Lug pattern.
just the rotors won't do.
Old Oct 9, 2004 | 11:50 AM
LSvtechatch97's Avatar
Default Re: 4x114 Swap? (HumanResource)
do it! 4 x 114 is gangster and running prelude wheels is pretty original.
Old Oct 9, 2004 | 10:18 PM
Default Re: 4x114 Swap? (FUKuPAYme)
Back up top
Read the first post
No flaming
The benefit of the 114 was for the wheels and the brakes
Sure I can run the brakes if I redrill but GASP I wouldn't have to redrill if the car was 4x114. Who cares if you don't like it. It's my car. Do I tell you how to mod your car?
Next guy says I can't swap it to 114 just by putting on rotors Thanks Captian Obvious You sell motors is your location. Yeah I wanna buy an engine from you Capt. O.
This forum needs help.
I ask questions on here and get people answering who I am amazed can even turn on their computer.
I figure out the answers to more of my own questions through trial and error vs. the help I get here.
If you are gonna say something asinine, or you don't know the correct answer or you're going to give your opinion on why it shouldn't be done or you're gonna say search.....
SHUT THE **** UP
It should be a forum rule.
Old Oct 11, 2004 | 07:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">Need to swap over Hubs to run any other Lug pattern.
just the rotors won't do.</TD></TR></TABLE>
That all the help u need.
The rest u can do for yrself
Extraneous work on a car JUST FOR A LOOK
FORUM DOESN'T NEED HELP
People that ask for help on an internet forum instead and flame on people that try to help&lt;&lt;&lt;NOW these guys need help
U need Jesus man
Old Oct 11, 2004 | 08:12 PM
. o 69 o .'s Avatar
i got the 4 x 114 conversion for my EG. IT came from a JDM 1996 ITR... bolts right up and you can run any 4 x 114 wheel you like
Old Oct 11, 2004 | 08:19 PM
JapJunkie's Avatar
Default Re: 4x114 Swap? (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">i got the 4 x 114 conversion for my EG. IT came from a JDM 1996 ITR... bolts right up and you can run any 4 x 114 wheel you like</TD></TR></TABLE>
Will this work for an ef hatch or rex?
Old Oct 11, 2004 | 08:32 PM
. o 69 o .'s Avatar
Default Re: 4x114 Swap? (JapJunkie)
i know you can swap on the rear without any problem... not sure about the fronts though... you have to do some searching. I don't knwo much about EF chassis
Old Oct 11, 2004 | 09:02 PM
Capt. O.,
Thanks for your help. What hubs do I need?
U need Jesus man
Old Oct 12, 2004 | 09:29 AM
. o 69 o .'s Avatar
you need to buy a complete 4 x 114 ITR conversion. you cant just change the hubs.
I'm going to wanr you now, this is an expensive swap for a long term car once it comes down to replacing parts.
Old Oct 13, 2004 | 10:57 PM
B16B,
Thank you for helping.
I have heard horror stories about finding 4 lug ITR discs.
That's why I was wondering if anyone had ever swapped the hub and bearings out of an Accord or something to make it work or even the whole knuckle.
Let me bounce something off of you quick since you seem like you might know.
If someone ran 94+ GSR knuckles on a CRX it would be all screwed up. That's why they need EX or 90-93 DA parts. Wouldn't using 96 ITR parts cause the same problems? It seems to me that they would be closer to GSR dimentions rather than CRX.
Old Oct 14, 2004 | 04:06 AM
. o 69 o .'s Avatar
hub is 44610-S10-000 without studs
or 44600-S10-000 with studs
bearing is 44300-S04-A02
Old Oct 14, 2004 | 05:07 AM
IntegraXSi's Avatar
The only other Hubs/knuckles that wont screw you up (geometrical) and are BOLT ON are 88-91 EX Sedan hubs.. With that Said you CAN have 4x114 but you have to have the HUBS pressed into your knuckles or ex knuckles.. Same with 5 lug
Old Nov 11, 2004 | 05:56 PM
wu tang's Avatar
Default Re: 4x114 Swap? (IntegraXSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraXSi &raquo;</TD></TR><TR><TD CLASS="quote">The only other Hubs/knuckles that wont screw you up (geometrical) and are BOLT ON are </TD></TR></TABLE> the 4x114 is bolt on
OrionTDS
May 28, 2010 05:55 AM
scootibum
Sep 13, 2007 03:00 PM
DunnDunn
Oct 24, 2006 10:54 AM
fr0stee tr00per
Nov 11, 2002 09:52 AM
