How to fix ecu immoblizer in 2001 GSR
Old Oct 8, 2004 | 06:36 PM
jasperl33
Guest
Posts: n/a
Default How to fix ecu immoblizer in 2001 GSR
I have a 2000 civic LX and bought a USDM 2001 GSR complete swap. 2001 gsr euc has immobiler in it I got the ignition switch come with the ecu. But someone told me that the ignition switch from the gsr won't fit into the civic. Is that true or not? If it is, can I use a 99 integra ecu instead? Will I be able to pass the State Referee since I live in California? Need some help. Thanks
Old Oct 8, 2004 | 07:02 PM
letmeseeyouskip's Avatar
Default Re: How to fix ecu immoblizer in 2001 GSR (jasperl33)
haha when you ask how to take or fix the immoblizer for 2001 ECU's people will think you are a theif.... you have two other ways either get an 99 GSR ecu but you will still need the harness from obd2b to obd2a or you can go chip with obd1 and jumper harness
Old Oct 8, 2004 | 09:16 PM
jasperl33
Guest
Posts: n/a
Default Re: How to fix ecu immoblizer in 2001 GSR (letmeseeyouskip)
but how about putting the ignition switch from the 2001 gsr into the civic. WIll that work? Does it fit into the civic? thanks
Old Oct 8, 2004 | 10:38 PM
jmk2888's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasperl33 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000 civic LX and bought a USDM 2001 GSR complete swap. 2001 gsr euc has immobiler in it I got the ignition switch come with the ecu. But someone told me that the ignition switch from the gsr won't fit into the civic. Is that true or not? If it is, can I use a 99 integra ecu instead? Will I be able to pass the State Referee since I live in California? Need some help. Thanks</TD></TR></TABLE>
Just pay someone to solider out the Immobiler chip, PM Katman he does it.
Old Oct 9, 2004 | 07:10 AM
jasperl33
Guest
Posts: n/a
Default Re: How to fix ecu immoblizer in 2001 GSR (jmk2888)
I talked to Katman already and the problem is the engine light will turn on all time and I can't pass the state smog test. Do you know if the ignition switch replacement will work? Thanks
Old Oct 9, 2004 | 08:59 AM
JdmCIVIC853's Avatar
If you have Proof that you bought it legally, Honda should take it off for you
Old Oct 9, 2004 | 09:38 AM
jmk2888's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasperl33 &raquo;</TD></TR><TR><TD CLASS="quote">I talked to Katman already and the problem is the engine light will turn on all time and I can't pass the state smog test. Do you know if the ignition switch replacement will work? Thanks</TD></TR></TABLE>
Just pull the light bulb out and go to State Ref. afterwards put the light bulb back in.
slimm82
Aug 11, 2010 05:14 PM
nuklang
Aug 4, 2006 06:33 PM
Tuan
Aug 30, 2005 05:11 PM
