DA seats in a EF ..
Old Oct 8, 2004 | 06:01 PM
superacecardriver's Avatar
Default DA seats in a EF ..
I just picked up a mint seat of Integra seats, I put them in my crx but there not bolted in. There really nice, but What needs to be done to the integra rails to fit?
Old Oct 8, 2004 | 07:39 PM
J.P.'s Avatar
Default Re: DA seats in a EF .. (crx1.8)
Just did this in my friends Hatch. You got 2 options:
Swap the rails from your EF seats, to the DA seats OR
Mark and drill new holes in the floor to match the DA rails, and use longer bolts and nuts (washers), to bolt them in. Your choice. My friend decided to drill new holes in her hatch, they are very sturdy and you cant see the bolts. Hope that helps a little
-jP
Old Oct 8, 2004 | 07:50 PM
Default Re: DA seats in a EF .. ([256] JP-03)
You can't get all 4 of them in though. Some of the holes on the rails are slanted. The fronts don't match. The only one I bolted down using the Da rails is the left rear one that is back by the ebrake in the back. Are you drilling them to the floorboard and do they stick out the bottom?
You think you could get pictures so I could get a idea what I need to do? Please
Old Oct 8, 2004 | 07:53 PM
Jonathan_ED3's Avatar
I'm pretty sure you can't just swap the Civic rails onto the seats and them still bolt into place. That didn't work in my sedan, anyway. The Civic seat was wider at the base so the mounting points were off.
Option C:
Swap the CRX inner rail onto the Integra seat. On my car I had to cut off the actual seat hinge and also weld it into place on the CRX rail.
Then drill the mounts off of the outer rail on the Integra seat. They are just riveted in place. Cut these same mounts off of the CRX outer rail.
Then bolt the CRX outer mounts back into the floorboard. Make them nice and tight.
Then lay the Integra seat down in place by lining it up with the inner rail. Remember, you swapped the CRX inner rail so it bolts into that side.
The outer rail will now rest (slightly off-center) on the CRX rail mounts. Mark exactly where they lay and/or do a quick spot weld to keep it in that location.
Take the seat back out and finish up the weld.
Bolt your new seat in just like it came from the factory
If my description is hard to understand I can post some pictures up.
I first did the longer bolts, nuts and washers and redrilled thing going on but it's really not safe and the seats were still impossible to get perfectly level. Got tired of it after a few weeks and decided to do it right.
EDIT: DO NOT SCREW INTO YOUR FLOORBOARD. DO NOT ALTER YOUR FLOORBOARD AT ALL...THIS IS NOT SAFE, AND THERE IS NO NEED TO DO IT.
Old Oct 9, 2004 | 03:08 PM
bebeon_ek's Avatar
drill the hoes a little bit on the integra rail. thats how i put them in my ef9 and ek and my friend as them in his eg
i'll pm you
FOR SALE SSR SUPER FINS EX-C WHEELS AND PARTS FOR DA - EF - EG
https://honda-tech.com/zerothread?id=1006421
Old Oct 9, 2004 | 03:24 PM
tweakedrice79's Avatar
Default Re: DA seats in a EF .. (bebeon_ek)
when i put si seats in my 4 door i had to mix the seat rails from both cars and they fit just fine
Old Oct 9, 2004 | 03:44 PM
Targa250R's Avatar
be professional
A friend of mine put DA seats in his '91 CRX HF. What you have to do is swap the entire seat pan.
Mike_ef
Jun 13, 2012 05:54 PM
carlosjdmcivic
20
Sep 19, 2010 10:01 AM
akshn1
May 4, 2009 08:44 AM
JDMblkguy
Oct 12, 2008 06:57 AM
dohdoh420
Feb 4, 2006 03:56 PM
