What are you running on the bottle
Old Oct 8, 2004 | 04:27 PM
FormulaGSR's Avatar
Default What are you running on the bottle
I'm sorry for reposting this. Its in the forced induction forum but not getting many responses,. So it was suggested that i move it here.
I'm curious what kind of times people are running on nitrous. Post what you running on the bottle, settup and your NA times
95GSR, 140K, shart ram, exhaust, azenis, 50 shot wet and a stock clutch
1/8 mile 9.8 NA
9.0@ 80mph hiting the juice at the about 60 foot mark in first, launching at 3500rpm
Old Oct 8, 2004 | 06:37 PM
b8er's Avatar
Default Re: What are you running on the bottle (FormulaGSR)
i would also like to see what other ppl are running but sorry i cant help you out, not on the bottle. but dont be expecting alot, the more ppl that know your set up can beat you
Old Oct 8, 2004 | 07:31 PM
Jokerluv's Avatar
6.89 in the 1/8th
but not in an import.......lol
Old Oct 8, 2004 | 11:10 PM
MAD SOHC's Avatar
Default Re: (Jokerluv)
Dont be afraid to spray out of the hole. You should be running atleast 9.4s in the 1/8th with that set up. Also make sure there is no water on your tires at all. Just incase you haven't figured it out yet Azenies SUCK for drag racing.
Old Oct 8, 2004 | 11:57 PM
RedZone's Avatar
Default Re: (MAD SOHC)
When car was a street car in 1997 the setup was:
12.3@115 with a stock b18c1 with a 6puck clutch, MSD 6A, fuel pressure regulator, on 15inch slicks with 100 shot direct. This was a full interior street car.......car was 2400 pounds
When car was turned into a race car in 2001 the set up was:
11.0@123 on a stock sleeve b18c1 block, JE 7cc pistons, crower rods, b18c1 head CTR cams, 140 shot direct in a car that weighed 1900lbs with duel Weber 45 DCOE side-drafts on 13x22x8 slicks.
here is a picture of when it had the side-drafts on it with direct-port!
Both setups shot out of the hole through all gears.
both weighed with driver
Old Oct 9, 2004 | 12:23 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (RedZone)
I was never really on the bottle since I was breast fed.
Old Oct 9, 2004 | 04:45 AM
.y2a.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry for reposting this. Its in the forced induction forum but not getting many responses,. So it was suggested that i move it here.
1/8 mile 9.8 NA
https://honda-tech.com/zerothread?id=898393
Shant from Kedimoto Racing - ls/vtec, gsr head, ctr cams, 81mm pr3 pistons on ls rods, arp rod bolts and head studs, c16 fuel, 120 shot, 1855lbs w/driver, 11.08@124.94
Old Oct 9, 2004 | 05:20 AM
reallycooleg's Avatar
Default Re: What are you running on the bottle (.y2a.)
i had a 55 dry shot on my ls hatch..ran a 15.0 n/a....never got run it with spray at the track really...but i ran my friend 03 mustang gt from a 2nd roll like 40mph and we were dead even through into 4th and then we shut down...but he ran a 13.8 in 1/4...i prob would not have pulled that but it would have close...i cant get out of the hole like he can...
Old Oct 9, 2004 | 05:38 AM
4piston's Avatar
Default Re: What are you running on the bottle (reallycooleg)
96 hatch, stock B18B, 60 shot dry. Car ran 15.3 @ 87 NA and 14.3 @ 96 on the bottle on street tires.
A friend has an EF hatch, full interior street car, stock B18A, 100 shot direct port. 12.5 @ 115. 24.5 MT
Old Oct 9, 2004 | 07:11 AM
SiR831's Avatar
What RPM were you lauching at?
Old Oct 9, 2004 | 10:22 AM
RedZone's Avatar
Default Re: (SiR831)
5500 on the street setup and 6000 on the race setup
Old Oct 9, 2004 | 10:31 AM
RaceProfessor's Avatar
I went 13.30's @ 106pmh in my old EK coupe with a USDM GSR I/H/E, clutch, and 50hp wet shot on drag radials.
Sam
Old Oct 9, 2004 | 10:33 AM
RedZone's Avatar
Default Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I was never really on the bottle since I was breast fed.</TD></TR></TABLE>
at 27, Im still breastfeeding!......
Old Oct 9, 2004 | 04:06 PM
Icey112's Avatar
91 crx si with a d16z6 i/h/e and 55 shot of zex went 14.8 in the 1/4 on street tires
92 civic cx with a b16a2 usdm i/h/e and gsr cams and gsr ecu with the same zex kit spraying a 65 shot went 8.8 at 86mph in the 1/8 on street tires.
Old Oct 14, 2004 | 04:54 AM
93H22ACX's Avatar
Default Re: (Icey112)
12.1@115 on 70shot
Old Oct 14, 2004 | 01:27 PM
SiR831's Avatar
Default Re: (93H22ACX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX &raquo;</TD></TR><TR><TD CLASS="quote">12.1@115 on 70shot</TD></TR></TABLE>
H22 on the bottle?
Old Oct 14, 2004 | 08:04 PM
Group Tenacity's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone &raquo;</TD></TR><TR><TD CLASS="quote">
at 27, Im still breastfeeding!...... </TD></TR></TABLE>
Same here...
Old Oct 16, 2004 | 11:59 AM
FormulaGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD SOHC &raquo;</TD></TR><TR><TD CLASS="quote">Dont be afraid to spray out of the hole. You should be running atleast 9.4s in the 1/8th with that set up. Also make sure there is no water on your tires at all. Just incase you haven't figured it out yet Azenies SUCK for drag racing.</TD></TR></TABLE>
I do run at least a 9.4, I run 9.0 in the 1/8th.
My clutch doesnt seem too happy when i spray out of the hole. I have an act waiting to go in though. I've had decent luck with my azenis for draging. They require some heating which is abnormal for a radial but with a little burnout the hook pretty well. Do you have a better suggestion for a street.drag lire. Nitto doesnt make the 205/50/15 555s anymore and evry other drag radial is to damn soft for daily driving. i'M OPEN TO SUGGESTIONS THOUGH.
Old Oct 16, 2004 | 03:35 PM
vtecmissle's Avatar
i ran 9.4 with bent valves and bald tires he should run way better than that and we have almost the same miles and mods.
Old Oct 16, 2004 | 11:24 PM
zeroracerh's Avatar
Default Re: (vtecmissle)
i run 9.9 all motor and 9.7 on bottle in the 1/8! i roll a d16y8
Old Oct 17, 2004 | 11:58 AM
lsvtecarod's Avatar
13.7 @ 102 89 crx si, full interior, 98 b18 non vtec wit 50 shot nx on bfg radials
Old Oct 17, 2004 | 11:30 PM
MAD SOHC's Avatar
Default Re: (FormulaGSR)
BFGs I dont now how I didn't see that you edited it didn't you!!!.......lol
Old Oct 18, 2004 | 04:43 AM
RobbieG35's Avatar
12 Years Strong
There was an EG hatch around here back in the day
LS/VTEC, S2S2 cams, 10.0:1 compression forged bottom end (pistons rods)
100 shot wet, consistent 7.8@92 mph 1/8 mile
Old Oct 18, 2004 | 09:10 AM
93H22ACX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR831 &raquo;</TD></TR><TR><TD CLASS="quote">
H22 on the bottle?</TD></TR></TABLE>
yes...11.8:1 compression with wet 70 with 24.5x8x13 lensos....i'm gonna try 22's next time...hopefully it'll give me better topend speed
Old Oct 18, 2004 | 11:38 AM
SadisticRacing's Avatar
12.6 @ 109.29--&gt; '90 Crx----- Jdm B16a i/h/e 75 dry shot on 22x8x13's.
