Can someone explain bore, stroke, rod/stroke ratios, etc?
bore is the size circularlly of your cylinders. stroke is how far/lengh your crankshaft moves your rods/pistons. rod/stroke is the size of your rods compared to the size of you lenghth of your stroke so if you have a really high stroke and a really small rod it will be low r/s ratio.
92_civic_eg
Mar 19, 2014 04:02 AM
