Need help w/ GE oil adapter plate (OE oil filter fitting won't come out of the block)
I'm assuming the GE adapter is attached with a "hollow bolt" and the spin-on oil filter nipple is what you are trying to remove. And since you've tried pliers you aren't concerned about reusing it. A large "easy out" for removing broken bolts/studs can be used to remove the threaded nipple. Hope this helps.
Jim
Jim
Thanks Jim but, I pulled the IM and took some vise grips to it.
Came out pretty easily that way. I just couldn't get leverage from underneath.
Phil
Came out pretty easily that way. I just couldn't get leverage from underneath.Phil
GReddyB18C
Jan 30, 2002 06:25 AM
