koni yellow spring perch question
I just put a set of koni yellows and H&R OE springs onto my 92 GSR. There are 3 different slots to put the spring perch on the struts, allowing you to control the ride height somewhat. The OE springs are rated at a .75" drop - which perch would I use if that is the drop I want?
I recently installed Koni Yellows and Eibach Prokit on my '01 GSR... I installed the springs on the middle perch....
looks and works great! You should enjoy the setup. Click on the link below...
https://honda-tech.com/zerothread?id=99424
[Modified by passion4healing, 12:11 AM 12/15/2001]
i have them set on the lowest perch with comptech springs and its low about 2.25 inches in the front and about 1.7 in the back, but I don't hit anything and have a camber kit, handles like a dream
Rayz_Si
Suspension & Brakes
Mar 28, 2007 07:10 PM
accordtuner1996
Aug 2, 2006 09:41 PM
b18c4door
Oct 9, 2003 09:01 PM
