tdc question... need help asap
Old Oct 8, 2004 | 09:31 AM
hatchinprogress's Avatar
Default tdc question... need help asap
im getting ready to do a valve adjustment and i started turning the crank (counter clock wise) and when i turn the crank the cams just go BACK where they were. any body know why this would happen? cuz on my last motor one cam kept "skipping" so it fucked up the motor (timing kept jumping) and this reminds me of the same problem.. and the other day when i looked at the marks on cam gears i noticed they wernt lined up (perfect) with eachother????? please help oh and both motors were/are dohc zc and the car is an ef (if that matters)
Old Oct 8, 2004 | 09:41 AM
RCautoworks's Avatar
Default Re: tdc question... need help asap (hatchinprogress)
Kind of hard to understand what your saying but how is the tension ?
Old Oct 8, 2004 | 09:48 AM
Default Re: tdc question... need help asap (90blackcrx)
im sorry if im rambling on im just worried that my timing will jump/skip i dont know about the tension by looking at the belt on the cams it looks a lil loose when i turn the crank, but i cant pull the belt by hand(so not super loose)
Old Oct 8, 2004 | 09:55 AM
89civicdx's Avatar
If you haven't loosened the belt tensioner bolt then the cams will just turn as you turn the crank pully
If you loosen the bolt and turn clockwise then the blet will skip.
Old Oct 8, 2004 | 10:03 AM
Default Re: tdc question... need help asap (89civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx &raquo;</TD></TR><TR><TD CLASS="quote">If you haven't loosened the belt tensioner bolt then the cams will just turn as you turn the crank pully
If you loosen the bolt and turn clockwise then the blet will skip.</TD></TR></TABLE> i havnt touch'd the belt tensioner, and the cams do move (forward) when i turn the crank but when i stop turning the crank the cams "jump" back to where they were....why???
Old Oct 8, 2004 | 10:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> i havnt touch'd the belt tensioner, and the cams do move (forward) when i turn the crank but when i stop turning the crank the cams "jump" back to where they were....why???</TD></TR></TABLE>
Are they turning back a little or a lot, a little would be like mm, a lot would be going around back in a circle. If that's the case your engine is possessed. What engine are you doing this on ?
Unfortunately that's not always true, when I was rebuilding an engine once I followed the procedures on tightening the belt was still loose, loose enough that one cam would jump a tooth every time it rotated around once. I found out that the tensioner need a little help, I had to pull up on the tensioner as I went threw the procedures of tightening the belt.
Old Oct 8, 2004 | 10:15 AM
dr_latino999's Avatar
I know what he is talking about; that is just the tension on the springs pushing back on the cam, if you don't get the correct piston at TDC that you're looking for, the cams are going to have resistence due to angle and impact of springs, etc. I experienced while doing a valve job with the head on a bench, it was a bitch and a half. As long as it isn't spinning more then a tooth back you should be fine.
Old Oct 8, 2004 | 10:22 AM
Default Re: tdc question... need help asap (dr_latino999)
well when they turn back i would say borderline of 1 tooth(amout goin back) and dr-latino999 how can i get tdc if they keep "jumpin" back??
LvN
May 5, 2008 07:06 PM
91 ZC hatchback
Feb 27, 2006 10:52 AM
MugenHonda
Mar 8, 2005 12:41 PM
full Circling
Jan 20, 2005 01:06 PM
scratchback
May 29, 2003 11:29 AM
